possible hydrolock aftershock
Old Aug 31, 2004 | 03:57 PM
alleyezonme's Avatar
Default possible hydrolock aftershock
ok so i did what everyone else did and drove through a HUGE puddle and the engine died. i tried startin it up to no avail. it would try to crank but wouln't even crank so i got it towed to my moms mechanic/friend. he just yanked the plugs and cranked it till the water shot out and it runs fine... almost. when i am just sittin there idling it vibrates a lil bit more than it should. it vibrates it waves, like someone is tapping you. my question is could this mean i have a slightly bent rod? i drove it home no problem just kept it in low RPMs until i got home. i am gonna go change the oil now. so do you guys think it is a bent rod? maybe a bent valve? i mean really really slightly bent just enough that it runs fine but gives off more vibration.
thanks
Old Aug 31, 2004 | 03:59 PM
KiDSoL's Avatar
Default Re: possible hydrolock aftershock (alleyezonme)
did you change the oil before you drove it home after he got the water out?
Old Aug 31, 2004 | 04:30 PM
heel_touge's Avatar
Default Re: possible hydrolock aftershock (KiDSoL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KiDSoL &raquo;</TD></TR><TR><TD CLASS="quote">did you change the oil before you drove it home after he got the water out?</TD></TR></TABLE>
i hope so.
Old Aug 31, 2004 | 04:35 PM
Turck's Avatar
Default Re: possible hydrolock aftershock (1slowcivic)
Id do a compression test if i were you.
Old Aug 31, 2004 | 05:57 PM
Default Re: possible hydrolock aftershock (Turck)
no i didn't change the oil i only drove it for like a half hour, but the oil is sooooo beat! i got lucky i even made it home! im letting it drain a lot before i dump more oil in!
another question... it it alright to pour 20w-50 in there and run it a bit and then change the oil again to hopefully flush it more? im asking 20w50 b/c that is what i have layin around, i do have my 4 quarts of 10w30 but i would change the oil again for that after i let it run to flush it out some. so will that even flush it out since it is a heavier oil?
Old Aug 31, 2004 | 05:59 PM
Andres-eh2's Avatar
sometimes when i have oil to spare, i leave the drain open between the oil change and just put oil in and let it spill out the other end.
Old Aug 31, 2004 | 06:10 PM
Default Re: (Andres-eh2)
and that helps to remove all the other junk?
Old Aug 31, 2004 | 08:40 PM
Default Re: (alleyezonme)
alright oil change is done! i can still rev up high and hit vtec and everything, but when i idle i idle at around 600 rpms instead of like 1000 (like it was b4 the whole mess) do you guys think i should be concerned about this? could it be idling lower b/c of water damage to wires or anything else?? thanks again!
Old Aug 31, 2004 | 09:46 PM
Kyles ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alleyezonme &raquo;</TD></TR><TR><TD CLASS="quote"> but when i idle i idle at around 600 rpms instead of like 1000 </TD></TR></TABLE>
thats where its suppose to idle at
Arthas
Jan 24, 2010 03:57 PM
Global688
Nov 27, 2007 05:27 AM
mikeycivic
15
Jul 17, 2006 12:52 PM
freezerburnv2
May 1, 2005 07:05 PM
usdmcrx
Feb 24, 2004 06:46 PM
