Car hesitation at 4500+ rpm and now it wont start!!!!!!
Old Aug 31, 2004 | 03:34 PM
b18c195's Avatar
Default Car hesitation at 4500+ rpm and now it wont start!!!!!!
Well this is the problem with my car.
Everytime i rev up my car past 4500 rpm it starts to bog like its not picking up speed and it hesitates. This was happening for like 2-3 days but today when i came home today i shut it off and tried to start it later on it wouldnt start again.
Engine cranks but wont turn over
I check all the fuses and for any leaks but couldnt fine anything. everything looked fine.
I changed the plugs and also changed the sparks plug wires but no luck
can any one give me any ideas on what to look for next and what the problem could be
here is my set up
95 gsr
T61 turbo
t4 manifold
valvespring and retainers
3 inch downpipe and exhuast
Old Aug 31, 2004 | 03:44 PM
Mase's Avatar
Default Re: Car hesitation at 4500+ rpm and now it wont start!!!!!! (b18c195)
any smoke or fluid leaks? do a compression test, and check to see if you are getting fuel and spark....
Old Aug 31, 2004 | 03:48 PM
Freemantle's Avatar
Default Re: Car hesitation at 4500+ rpm and now it wont start!!!!!! (Mase)
I say the same. Were you missing before the car shut off the last time? Were you failing to hit the VTEC crossover?
Old Aug 31, 2004 | 04:17 PM
1boostedcivic's Avatar
Default Re: Car hesitation at 4500+ rpm and now it wont start!!!!!! (Freemantle)
fuel pump??? do u have a fuel gauge? whats the psi of fuel are u getting?
Old Sep 8, 2004 | 09:56 PM
PrettyLude's Avatar
i think the injectors are flooding out the car, making it hard to start
Active EF
Feb 21, 2015 08:56 PM
civic46
11
Sep 12, 2010 05:25 PM
Phantastic
May 28, 2010 03:15 PM
Dnycest
Apr 7, 2007 10:31 AM
OrangeBoost
Jun 30, 2006 09:15 AM
