Lower oil pressure after rebuild
What does this mean? Is it a bad thing?
I used to get right around 70-72 PSI at 3000 RPMS before the rebuild, and now its right around 65 PSI. Idle is still the same as it was before at around 20 PSI.
I was using Mobile 1 before and now Im using regular oil, not sure if that has an effect on things.
Should I be concerned?
Yes I got a new oil pump as well..maybe that is why its lower now.
Ill be changing this oil at 1000 mile mark and we'll see then.
Is synthetic thinner/thicker then regular oil? Would it cause a change in pressure?
fr3dy_1
17
May 23, 2008 11:33 PM
hatchinprogress
Jan 7, 2006 07:48 AM
gaskleppie
Sep 27, 2003 06:45 AM
