AC/IDLE PROBLEM.
Old Aug 31, 2004 | 12:28 PM
effinnwackk's Avatar
Default AC/IDLE PROBLEM.
Whenever I just sit there waiting for someone in neutral just sittin' there while the car runs THE A/C goes on.. WHAT THE HELLLLLL.. whyy.. The thing isnt even on and it goes to a/c im not even using the fan.. why does it do this?? is it part of the idle to keep the car on? 1991 crx.. iono if this helps also but i dont have the a/c belt.. everytime i just sit there while the engine is in neutral it eats up the rpms.. and yea im thinkin this is a problem because the a/c goes on by itself? whyyy. help and thanks in advanced..
Old Aug 31, 2004 | 01:32 PM
Jonathan_ED3's Avatar
ummm...if you have no a/c belt there's no way your a/c system is coming on.
By 'eats up the rpms' do you mean you have a high idle?
Old Aug 31, 2004 | 09:32 PM
Default Re: (Jonathan_ED3)
no my idle is at like the first line.. but yea the a/c goes on automatically and it goes higher... and yea..
example.. I sit there the idle is at the first line.. then out of no where it jumps to like 1 rpm and the ac light goes on. and stays there for like 3-5 min.. then the thing goes back to normal and the ac light goes off..
Old Sep 1, 2004 | 10:09 AM
can any one help me.
Old Sep 1, 2004 | 01:52 PM
Default Re: (pinoyboiWONDER)
any one?
Old Sep 1, 2004 | 02:11 PM
4drEF's Avatar
Keyboard Humorist
Default Re: AC/IDLE PROBLEM. (pinoyboiWONDER)
Your car is possessed.
Remove the A/C switch and see if it still does it.
If the A/C light on the switch is coming on then it sounds like the switch is shorting somehow.
Call a priest and have a full blown exorcism.
Old Sep 4, 2004 | 09:15 PM
Default Re: AC/IDLE PROBLEM. (4drEF)
possessed haha. how gay. but seriously the buttons out (AC OFF) but when idlin out of no where the light comes on and the ac eats it up (the button is not push'd in) the light comes on even though its not on.
Old Sep 7, 2004 | 02:30 PM
sincrx's Avatar
When i turn my ac on the revs bottom out hardcore, and the car almost stalls, is it normal to be sucking so much revs?
Old Sep 7, 2004 | 02:36 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sincrx &raquo;</TD></TR><TR><TD CLASS="quote">When i turn my ac on the revs bottom out hardcore, and the car almost stalls, is it normal to be sucking so much revs?</TD></TR></TABLE>
Yes, but there is a connection on the ECU that is supposed to bump up the idle for you when the A/C is on.
Maybe your wire is broke or something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoyboiWONDER &raquo;</TD></TR><TR><TD CLASS="quote">possessed haha. how gay. </TD></TR></TABLE>
Not as gay as your avatar... looks like a dancing green ***** with legs
Old Sep 7, 2004 | 03:48 PM
its a deformed teletubby
Old Sep 7, 2004 | 04:28 PM
CRX_Control's Avatar
id say unplug that thing and see what happens , if it still comes on, then call the exorcist
Old Sep 7, 2004 | 09:57 PM
sincrx's Avatar
Ahh how do i check the wire? i never even seen my ecu let alone checked it
Old Sep 7, 2004 | 10:08 PM
johnclaunch's Avatar
If the a/c light is actually coming on without the button being pushed, then there is def. a short in the a/c system. However, when I had my a/c compressor off for service a while back, the car did NOT jump rpms if the a/c was switched on. Without the a/c system pressure, the rpms did not jump at all. Just like I had done nothing except that the blue a/c light was on. If you have no belt on the a/c compressor (why the hell not, it's still summer!?) then your rpms should do nothing when the a/c is switched on. The problem is tied, but not sure where...
Old Sep 7, 2004 | 10:36 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: AC/IDLE PROBLEM. (sincrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sincrx &raquo;</TD></TR><TR><TD CLASS="quote">Ahh how do i check the wire? i never even seen my ecu let alone checked it</TD></TR></TABLE>
your ECU is under the plate under the carpiet on the passenger side.
here aresome helpfull pics
it's not the greatis pic but see that pannel on the passenger side? under that is ur ECU
Old Sep 8, 2004 | 05:00 AM
crx_88_si's Avatar
Default Re: AC/IDLE PROBLEM. (johnclaunch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnclaunch &raquo;</TD></TR><TR><TD CLASS="quote">If the a/c light is actually coming on without the button being pushed, then there is def. a short in the a/c system. However, when I had my a/c compressor off for service a while back, the car did NOT jump rpms if the a/c was switched on. Without the a/c system pressure, the rpms did not jump at all. Just like I had done nothing except that the blue a/c light was on. If you have no belt on the a/c compressor (why the hell not, it's still summer!?) then your rpms should do nothing when the a/c is switched on. The problem is tied, but not sure where...</TD></TR></TABLE>
actually.. this is why the idle gets high. the a/c switch shorts out, turning the a/c on. the ecu see's the a/c is on and bumps the idle to compensate. although the belt is detached and the compressor isn't "using up" any rpms so the idle seems higher than it should be.
disconnect the plug behind the a/c button on the hvac controls.
Old Sep 8, 2004 | 03:38 PM
sincrx's Avatar
Default Re: AC/IDLE PROBLEM. (JC18)
Cheers for the diagram, i got a dohc zc non vtec lol, so will be hard, but ill just look for loose wires etc, if u hav n e idea which one is the ac idle one to make my idle come bak u (e.g. wat colour) plz tell me
Old Sep 9, 2004 | 07:21 AM
crx_88_si's Avatar
B3 = A/C Compressor Clutch Relay Control = YELLOW
B4 = A/C on Input = YEL/GRN
Old Sep 9, 2004 | 07:45 AM
4drEF's Avatar
Keyboard Humorist
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">B3 = A/C Compressor Clutch Relay Control = YELLOW
And for pretty pictures and stuff...
http://www.fourthgenhatch.com/mpfi.html
Old Sep 9, 2004 | 08:25 AM
crx_88_si's Avatar
Default Re: (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.fourthgenhatch.com/mpfi.html</TD></TR></TABLE>
uh.. that pinout for the mpfi says B8 = a/c switch ???
susy76
May 26, 2013 02:38 PM
213374U
Aug 19, 2009 07:47 AM
vietboixstunnah
Aug 7, 2003 12:41 PM
FLCivic
Sep 19, 2002 11:54 AM
