CLUTCH question automatic 1995 HONDA CIVIC lx sedan
HI, I am looking at this used car and the woman said sometimes it is hard to get the gear past reverse. for me it felt fine
is this a sign of anything >?
please respond ASAP
veraisthebest@aol.com
please respond ASAP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vera1018 »</TD></TR><TR><TD CLASS="quote">CLUTCH question automatic 1995 HONDA CIVIC lx sedan</TD></TR></TABLE>
Are you okay?
Are you okay?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vera1018 »</TD></TR><TR><TD CLASS="quote">HI, I am looking at this used car and the woman said sometimes it is hard to get the gear past reverse. for me it felt fine
please respond ASAP
veraisthebest@aol.com</TD></TR></TABLE>
wow,when is this gonna be moved to GDD to get flamed?
please respond ASAP
lol... i mean for the gears... what is it called? if not a clutch... Gears?
I thought you would understand when I said "reverse"... it's not a 5 spd it IS automatic, but the woman says sometimes its hard to get it passed reverse... make any sense?
what's gdd?
I came here for advice... not to be mocked. if you guys really know as much as you pretend to know, you would understand what I am asking
Well, you never know..
If it goes into reverse easily for you, but hard for her.. then there must be a difference between what you and her do.
Or maybe she doesn't press the button on the shifter all the way in.
Usually Reverse is on a seperate gear.
In an auto it is called a torque converter, which replaces the clutch disc in a manual. So it takes the same job just called something else, so you shouldn't get flamed.
Check the converter, than it could be the reverse gear is going out.
