Problem w/H22A Turbo install. Stalling out, Oil Vaporing from breather, Backfiring, Pulsating at 3r
Old Aug 31, 2004 | 09:33 AM
KaRiZMa's Avatar
Default Problem w/H22A Turbo install. Stalling out, Oil Vaporing from breather, Backfiring, Pulsating at 3r
I finally got my car back from the shop after 5 months! I have the JDM h22a installed and the rev hard turbo kit. I was driving it home, and every time i slow down to the point where the car starts idling...it will stall out. There is oil vaporing out of the little breather on the head and it smells. When i rev it past like 4k rpm it will smell heavily. I disconected the 2nd fuel pump because it wouldnt shut off for some reason...there is less backfiring now but there is still some backfiring. When i put it in 3rd 4th and 5th and press the gas pedal halfway or more...the car pulsates and feels like its choking. Any help or ideas as to what might be wrong? I really appreciate it. Thanks
Old Aug 31, 2004 | 09:55 AM
ash.zero's Avatar
what's your fuel setup?
Old Aug 31, 2004 | 10:05 AM
Lostcb7's Avatar
Default Re: (ash.zero)
It sounds like you had a shop do this swap/setup, and I would definately take it back to them and have them fix ANYTHING that wasn't right.
Old Aug 31, 2004 | 11:14 AM
KaRiZMa's Avatar
Default Re: (Lostcb7)
The fuel setup is stock injectors and its running on stock fuel pump and a second fuel pump (MSD) conected to a vortec fmu...
Shop did it and i took it back to them yesterday. they dont really seem like they know what is wrong so i figured i might post here and maybe someone can help out.
Old Sep 27, 2004 | 03:19 PM
90babyblue's Avatar
Default Re: (InnoVationZ)
thats your problem u need bigger injectors and a stronger main fuel pump
Old Sep 27, 2004 | 03:44 PM
tony d's Avatar
I don't know **** about turbo, but I do know that the shop should know and fix what ever is wrong!
Old Sep 27, 2004 | 05:40 PM
ash.zero's Avatar
Default Re: (tony d)
if you invested all that money on a h22 and turbo, get a REAL fuel management. fmu, inline pump, and check valve/missing link will NOT do that setup the justice.
i HIGHLY recommend hondata or aem ems.
take it to a REAL tuning shop.
Old Sep 27, 2004 | 09:48 PM
AutoWerks's Avatar
check your compression...
Old Sep 27, 2004 | 10:54 PM
PrettyLude's Avatar
u got way too much gas that's why its choking, is it popping under a load?
Old Sep 28, 2004 | 04:39 AM
iakona's Avatar
check your plugs
check your timing
Adjustable FPR
Walbro in-Tank Pump (no dual pumps)
RC 310 or 440 cc injectors
Hondata s200
that should do it for you. try to keep the system as simple as possible.
hondaaccord94
Dec 30, 2006 10:14 PM
buttsneeze
Feb 19, 2006 02:27 PM
hksturbolude
Feb 2, 2004 08:01 PM
Chubs
Aug 1, 2003 09:41 PM
