converting an arc welder to a tig welder...
Old Aug 31, 2004 | 09:07 AM
buckfittyone's Avatar
Default converting an arc welder to a tig welder...
has anyone heard of this or know how its done?if theres a link with some info or if anyone knows anything please post
Old Aug 31, 2004 | 11:00 AM
civicross's Avatar
Default Re: converting an arc welder to a tig welder... (buckfittyone)
http://tigdepot.com/products/p35TD-BBTF.htm
Old Aug 31, 2004 | 01:11 PM
Default Re: converting an arc welder to a tig welder... (civicross)
Old Sep 1, 2004 | 12:25 AM
tekstyle's Avatar
aww man. u have to strike the arc? i thought u can just use the foot pedal
Old Sep 1, 2004 | 07:30 AM
legendboy's Avatar
Default Re: converting an arc welder to a tig welder... (tekstyle)
The only thing you may find annoying is not being able to adjust the amperage with a foot petal. We have an old 300a Lincon buzbox here at work with on old Lincon hi-freq tig module and it works so so.
Old Sep 1, 2004 | 07:52 AM
kb58's Avatar
Banned
Default Re: converting an arc welder to a tig welder... (legendboy)
You have to ask yourself, "Do I want to make a welder, or make parts for the car?" These side projects can take away all your time from what you really want to do.
Old Sep 1, 2004 | 10:58 AM
Default Re: converting an arc welder to a tig welder... (kb58)
ur right kb58,it would be a bit much to go through all that for some charge pipes and exhaust.
can exhaust piping be arc welded?
Old Sep 1, 2004 | 11:59 AM
kb58's Avatar
Banned
Sure, small stick at low current.
Old Sep 1, 2004 | 02:17 PM
Canuk_SiR's Avatar
I don't think you can weld anything thinner then 11 gauge sheet metal with stick. But if you try, then use 6014 rods, and set your welder to electrode positive or straight current, so the arc doesen't penetrate as it would if it was set to reverse.
good luck with stick and exhaust piping
Walterronny
Welding / Fabrication
15
Oct 30, 2013 12:50 PM
NipTucked
11
Apr 11, 2009 08:20 AM
See Are X
Jul 16, 2008 10:19 AM
ILLICON3000
14
Sep 16, 2004 01:38 AM
leeit2me
Nov 15, 2003 09:49 AM
