B20 Vtec oil line question
im doin wanna do B20 vtec but the place on the head where u tap the oil line right by the Intake Manifold is welded shut....because it was cracked there and i had to get it welded...is there anywhere else on the head that u can run the oil line...i heard u can put it somewhere under the distributor....if there is let me know and if u have pics that would be great...thanks in advance
You can run the oil supply line to a hole near the distributor.It is plugged off from the factory.It will have the same effect.I dont have any pics because I have had no need to supply oil from thise point,but it will be very easy to find..If you cant find it by looking at the head for a second than you shouldnt be working on cars.I dont remember if it is directly under the distributor or just lower and to the side.When I go up to the shop later today ill look and may take some pics.
eg6-trans
Jan 7, 2008 10:52 AM
