car will not start when cold...anyone have this problem?
Old Aug 30, 2004 | 11:15 PM
sleepy_vtec's Avatar
Default car will not start when cold...anyone have this problem?
If it is cooler air out side, most of the time night and morning, the car will not crank up at all. It will just turn over and over and never crank up. I am thinking it is a problem with the distributor. Has new plugs and wires. And new injectors. i have heard someone mention the Main relay going bad? Any ideas guys? It is a stock 90 ex.
Old Aug 31, 2004 | 11:15 AM
Default Re: car will not start when cold...anyone have this problem? (sleepy_vtec)
bump
Old Aug 31, 2004 | 03:22 PM
tjohnson329's Avatar
it is probaly your battery. Your battery probaly has no more cold cranking amps. This just happened to my car. when your car doesn't start at night or when it is cold and you get a jump does it start then. if so it is the battery. check your clock time in your car, has it been reseting itself to 12:00 recently?
Old Aug 31, 2004 | 05:50 PM
DragonTLS's Avatar
did you replaced the distributor cap and rotor
Old Aug 31, 2004 | 08:14 PM
Default Re: car will not start when cold...anyone have this problem? (DragonTLS)
no it isnt the battery...brand new. It has to do with the something electrical like the distributor or a relay or something. This has had to happen to someone else. I took off the cap one day and took a nail file to the nodes on the rotor and cap. It then cranked up. Think it may just need a new rotor or cap? I have an extra h22 cap sitting around. Think that would fit on it?
Old Sep 1, 2004 | 07:12 AM
Turbowa's Avatar
You'll want to do what dragon tls said, replace the dist cap and rotor. Your probably getting some moisture in the cap when its cool out and when it warms up it dries out the cap.
Old Sep 1, 2004 | 07:32 AM
BlazeTeck2000's Avatar
i have the a/c compresor $40 ...you pay shipping
Old Sep 1, 2004 | 08:29 AM
Default Re: car will not start when cold...anyone have this problem? (BlazeTeck2000)
a prelude compressor? sorry i am actually in the prelude forum, my g/f has an accord, that is why i posted here.
Old Sep 1, 2004 | 08:30 AM
what exactly would the moisture do? Why would that present it from starting?
Old Sep 1, 2004 | 10:39 AM
JimBlake's Avatar
Hairline cracks or tiny defects in the surface of the cap create a short circuit across the surface of the cap, when they get any moisture. Watch for arcing in the dark. As soon as the moisture dries out it's OK. If you can start it after drying the distributor cap with a hairdryer, then this is a pretty good guess.
The main relay usually screws up when the interior of the car is really hot, like sitting in the sun.
Since the starter cranks (you said??) that means the battery is good.
Mikeedubb
Oct 11, 2012 06:00 PM
fortyfacemohwhat
Oct 17, 2008 05:40 PM
lacking vtec
Jun 23, 2006 07:47 AM
vietboixstunnah
Aug 27, 2002 06:34 PM
mjb240z
Apr 10, 2002 06:27 PM
