Would this be bad on my suspension?
Ok on the front of my 99 hatch the passenger side sits higher than the driver side due to some sort of accident. I was wondering if it would be bad if I had coilovers in the front and adjusted the passenger side so the coil spring is lower than on the driver side and so then the two sides will be even.
I gotta get my new rear struts on and ride them for a while before an alignment. I've been changing my suspension a lot lately.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duh blacksheep »</TD></TR><TR><TD CLASS="quote">your tires might wear unevenly. get a wheel alignment and a get a printout</TD></TR></TABLE>
I agree with him......you should get it fixed, coils won't help...maybe visually....looking at the car....but riding in it....looking at the tired....totally diff.
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Here's pictures of it. I'm not even sure if it's the driver or passenger side that's the problem to tell you the truth. Definitely not a spring or strut problem because I swapped them out with 3 different sets of springs and two different sets of struts.
Driver Side
Control arm angled up higher (can't see the strut top hat)
Passenger Side
Control arm angled lower or just level with the ground (top hat visible)
Driver Side
Passenger Side
From: Canyon mother fucking Country, California, United States of America
You may want to look into what is causing the the problem and fix it. >It's probably cheaper than coil overs i bet, the suspension parts can be replaced aswell as the subframe.
It's really the least of my worries right now. I gotta replace my rear struts and fix the exhaust leak I have first which are more serious. I'll have a shop check it out. I already have coilovers that I don't use.
See if you can find a frame shop. OR a reputable body shop. They should be able to straighten the frame out. Expect to pay around 800. And for that price they should do an EXCELLENT JOB on straightening the frame. Be pissed if they don't.
Modified by murtnabila at 12:19 AM 8/31/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien »</TD></TR><TR><TD CLASS="quote">Here's pictures of it. I'm not even sure if it's the driver or passenger side that's the problem to tell you the truth. Definitely not a spring or strut problem because I swapped them out with 3 different sets of springs and two different sets of struts.
Driver Side
Passenger Side
Control arm angled lower or just level with the ground (top hat visible)</TD></TR></TABLE>
That's pretty f'ed up!
Driver Side
Passenger Side
i had the same problem on my car due to an accident it looked just like your pic. i swithed out every thing struts spings then some one told me to get a whole new suspension set up i mean the whole thing spindal SP* hub every arm going up down left right and sure enough that was the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murtnabila »</TD></TR><TR><TD CLASS="quote">See if you can find a frame shop. OR a reputable body shop. They should be able to straighten the frame out. Expect to pay around 800. And for that price they should do an EXCELLENT JOB on straightening the frame. Be pissed if they don't.
Modified by murtnabila at 12:19 AM 8/31/2004</TD></TR></TABLE>
if you do this make sure its a reputable shop - with a Frame Machine & Measuring/Measurment Machine to go along with it...that way they can get the frame back to (or as close to) OEM specs...BS them a 'lil tell them you are putting thousands into the car & you plan on racing it (legally) on a road race track
too many non enthusiuasts get there frame fixed so everything just looks okay - make sure you tell them you are NOT one of those people
EDIT - it could be something was not installed correctly or to OEM specs as well - which would be much cheaper to fix than the frame
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NRGchick »</TD></TR><TR><TD CLASS="quote">i would just go to a junkyard and pick up the whole front corner suspension and replace it all, you can get it for damn cheap.</TD></TR></TABLE>
i would try that first
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheRwillFUKyou666 »</TD></TR><TR><TD CLASS="quote">You may want to look into what is causing the the problem and fix it. >It's probably cheaper than coil overs i bet, the suspension parts can be replaced aswell as the subframe. </TD></TR></TABLE>
good idea.. fix the problem the right way.. replace the messed up parts.
Well didn't get it checked, but my friends' TWO EG hatches had the exact same problem. Front driver side sat lower than front passenger side. You think it's a coincidence or just faulty honda parts? And not sure about this, but doesnt 75% of the motor sit on the driver side anyway? Could that be the problem?
