four wire O2 sensor with OBD0
I'm running obd0 and a 4 wire 02...works fine. O2 has 4 wires, black and green=ground, white=ecu, other black=switched power. Ecu will still get a reading from a single lead wire except it'll be heated once you start ignition...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec »</TD></TR><TR><TD CLASS="quote">I'm running obd0 and a 4 wire 02...works fine. O2 has 4 wires, black and green=ground, white=ecu, other black=switched power. Ecu will still get a reading from a single lead wire except it'll be heated once you start ignition...</TD></TR></TABLE>
how's your milage? I was under the impression the 4-wire sensor has different values for certain a/fs then the 1-wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">
how's your milage? I was under the impression the 4-wire sensor has different values for certain a/fs then the 1-wire.</TD></TR></TABLE>
They do.
They do.
Mileage?...easy driving, 550 km on a tank of gas (jdm cluster)...
550 x .6 = 330 miles
330 miles/ 10 gallons = 33 miles per gallon
and its about 450 km if I'm driving it hard...so that's at least 25 mpg (fully built lsvtec motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec »</TD></TR><TR><TD CLASS="quote">Mileage?...easy driving, 550 km on a tank of gas (jdm cluster)...
and its about 450 km if I'm driving it hard...so that's at least 25 mpg (fully built lsvtec motor)</TD></TR></TABLE>
wow that is dope and by u mentioning KPH u have a si-r cluster as I do
crazy hope mine gets this mileage
too
too
okay kewl beans....how will it effect my performanceif i run a single wire 02 sensor on a header that has the bung down by the cat?
Modified by daidilus at 6:23 PM 9/1/2004
bmxtrev
Jun 28, 2012 09:17 PM
