need help..terminal 4 on fuel pump relay cant be found
Old Dec 5, 2001 | 10:37 AM
threatcon13's Avatar
New User
Default need help..terminal 4 on fuel pump relay cant be found
im installing the inline fuel pump for my drag 3 kit..i found the fuel pump relay,and needed to connect positive lead from secondary fuel pump to terminal 4 on the relay...but terminal 4 is non existant...what should i do??? please help! thanks
Old Dec 5, 2001 | 11:05 AM
GSR_Dude's Avatar
Default Re: need help..terminal 4 on fuel pump relay cant be found (turbo01gsr)
Do you have a volt meter ? I would just probe the fuel relay and see which one goes live when the ignition is turned on. But thats me...
Old Dec 5, 2001 | 06:48 PM
Farnsrocket's Avatar
Default Re: need help..terminal 4 on fuel pump relay cant be found (GSR_Dude)
I have a 95 GSR and the wire is green and yellow....it may be the same with an 01'..........it's in one of the corners of the relay. Don't the directions tell you to try #7 if #4 does not work??? A Service Manual will show you exactly where it is.
Old Dec 5, 2001 | 09:18 PM
New User
Default Re: need help..terminal 4 on fuel pump relay cant be found (Farnsrocket)
i used the voltmeter method worked like a damn charm thanks gsr dude
Old Dec 5, 2001 | 09:22 PM
dustin's Avatar
The terminal you want is at the bottom left when looking at the connectors.
Dustin
civic28
Mar 26, 2014 04:18 PM
briansrc
Jul 13, 2010 09:01 AM
Jamison
Jul 11, 2002 12:07 PM
RCSIVTEC
May 12, 2002 10:14 PM
