Replaced Knock Sensor. Do I need to reset my battery????
Old Aug 30, 2004 | 05:14 PM
EuRoBrO's Avatar
Default Replaced Knock Sensor. Do I need to reset my battery????
Just as title says, I replaced my knock sensor because I broke it from a IM install and the car runs fine now, no safe mode BS. But just for the hell of it I wanted to check and see if the EGR was the only code I was throwing, and sho-nuff there was code 23(knock sensor) Just curious if I am supposed to reset the battery after replacing the knock sensor or if the ECU will restart by itself after every shup off/turn on. Thanks!
Old Aug 30, 2004 | 05:28 PM
SlammedAccord96's Avatar
Default Re: Replaced Knock Sensor. Do I need to reset my battery???? (EuRoBrO)
Yeah you might want to reset it anyway, just in case, these things can be complex . No the ECU doesn't automatically reset itself tho. If you don't wanna loose your radio memory and all that, you could just unplug the ECU...
bilshatri
May 25, 2012 11:48 AM
davidu
23
Oct 15, 2008 06:30 PM
ek4 sir civic
Jun 28, 2007 07:09 PM
trinitycivic93
Jul 27, 2005 02:33 PM
CRexcellence
Apr 29, 2003 09:05 AM
