GSXR Throttle Bodies (a thread continuation)
Old Aug 30, 2004 | 02:17 PM
Dogginator's Avatar
Daisy... Daisy...
Default GSXR Throttle Bodies (a thread continuation)
I made this thread to keep continuity of a good topic. The orginal thread was locked due to size, but the link is here:
https://honda-tech.com/zerothread?id=775280
I'll ask Lip to put this link in his last post on the original thread.
Old Aug 30, 2004 | 05:19 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: GSXR Throttle Bodies (Dogginator)
The 2000-2003 GSXR 750 throttle bodies measure 50 mm (may be 49.5 mm) at the inlet and 42 mm at the outlet. These are the same dimensions as the GSXR 1000 throttle bodies. I measured my throttle bodies. They are stamped with code 35F0. Check these links for the GSXR 1000:
http://www.mcnews.com.au/NewBi...2.htm
http://www.motorcyclistonline....gsxr/
Modified by Dogginator at 8:26 AM 8/31/2004
Old Aug 31, 2004 | 02:02 AM
edc's Avatar
edc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">The 2000-2004 GSXR 750 throttle bodies measure 50 mm at the inlet and 42 mm at the outlet. These are the same dimensions as the GSXR 1000 throttle bodies. Check these links for the GSXR 1000:
http://www.motorcyclistonline....gsxr/</TD></TR></TABLE>
Copied from old thread:
GSXR750 bodies, internal diameter of 48mm at opening taper down to 40mm and 44mm where the injector leads in.
Above were measured for me from a 1999 model with the desginaion WW, apparently the same as WX.
Old Aug 31, 2004 | 04:24 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: GSXR Throttle Bodies (edc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edc &raquo;</TD></TR><TR><TD CLASS="quote">GSXR750 bodies, internal diameter of 48mm at opening taper down to 40mm and 44mm where the injector leads in.
Above were measured for me from a 1999 model with the desginaion WW, apparently the same as WX.</TD></TR></TABLE>
Indeed. The 96-99 GSXR 750 throttle bodies are smaller. They are stamped with the code 33E5.
Old Aug 31, 2004 | 05:42 AM
Speedz's Avatar
i'm still working on my runners.. got everything else pretty much worked out
here's pic of the epoxy i've gotta port smooth..
Old Aug 31, 2004 | 08:03 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
I havent read all of the other post yet...but i have a few questions. First of all...what would be the benefits of having shorter/longer runners with ITB's? It seems like shorter would give you better throttle response...but im not sure if longer ones would have that much if any benefit. Also, how do you figure out what size ITB's youll need? Thanks
Old Sep 6, 2004 | 08:17 PM
Speedz's Avatar
Default Re: GSXR Throttle Bodies (sCeRaXn)
here's one of the runners thats done, i filled in the injector hole as u can see by this pic.
also got a question for you guys who've alread done the diy itbs.. what would work better: having one vaccuum line coming from runner #1 for brake booster? or just have it plugged into the vaccuum log with the rest of the vaccum lines?
Modified by Speedz at 5:28 AM 9/7/2004
Old Sep 10, 2004 | 09:51 PM
Speedz's Avatar
Default Re: GSXR Throttle Bodies (Speedz)
finally took the time to finnish these runners inside.. heres pics
next is drilling holes for my vaccuum lines to go to the vaccuum log.
Old Sep 11, 2004 | 07:45 AM
Dogginator's Avatar
Daisy... Daisy...
It looks like its coming along. Did you have any problem with the manifold warping when you welded the tubes?
Old Sep 11, 2004 | 08:53 AM
Speedz's Avatar
thanks man, no my welder was very careful about that.. i'm probably gonna surface the flange tho anyway. (i'm a perfectionist)
Old Sep 15, 2004 | 09:35 PM
Speedz's Avatar
another update
Old Sep 15, 2004 | 10:52 PM
mEr's Avatar
mEr
looking good
Old Sep 16, 2004 | 09:40 PM
Speedz's Avatar
Default Re: GSXR Throttle Bodies (mEr)
thanks
still got more work to do.. gonna try to get the block in my hatch this weekend still got alot of other things to do before i can start the thing tho.
gotta piece together an engine harness first LOL
Old Sep 17, 2004 | 04:34 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedz &raquo;</TD></TR><TR><TD CLASS="quote">thanks
It looks like it is coming along well. Those velocity stacks are quite nice. Where did you find them? Have you check for brake booster clearance?
Old Sep 17, 2004 | 05:42 AM
Speedz's Avatar
not yet.. but when i had the ITB's in my engine bay, i think it was ok..
here's the guys email address i got them from (was waiting from email from him befor i posted) FASTLISLE@aol.com
he has them made locally.. he gets them in 3 sizes.. 1-7/8....2-1/8 and the 2-1/2 sizes.. and has a large supply of each size..
the 2.1/8" stacks fit perfect on the gsxr 1000 itbs. (at least they do on mine)
Old Sep 17, 2004 | 06:01 AM
MysteryWagon's Avatar
where the throttle bodies just laying around or did you purchase them?
and if so how much do a set of GSXR TB's go for?
Are there any charts for throttle body sizes that are appropriate to use with certain set ups?
info would be great
thanks alot
Justin
Old Sep 17, 2004 | 03:46 PM
Speedz's Avatar
Default Re: GSXR Throttle Bodies (MysteryWagon)
i bought mine off Ebay for $115 shipped.. they normally go for around 150 or so from what i've been seeing.. i guess it depends on if u get lucky or not as to how much you'll end up paying.
Jenvey's website has alot of good info on ITB sizing.. they also give a good idea on how a system should be designed.
here's a link to their Advice & FAQs http://www.jenvey.com/~Tech_QA.htm
also i suggest reading the VERY long archived thread that's posted at top of this thread. lots of good info there as well.
and here's a small update on fitting my stacks this afternoon.. i think they came out well.
Modified by Speedz at 1:08 AM 9/18/2004
Old Sep 17, 2004 | 04:14 PM
EKhatch's Avatar
Very, very nice work Speedz.
Old Sep 17, 2004 | 09:59 PM
Speedz's Avatar
Default Re: GSXR Throttle Bodies (EKhatch)
thanks man, gonna try to have the hatch running in 2 weeks for our Oct2 race.. u should come on over from ID
Old Sep 18, 2004 | 04:25 PM
OLM-02R's Avatar
that looks awesome man...keep us updated...
Old Sep 18, 2004 | 04:43 PM
GreensleeperB16's Avatar
Default Re: (OLM-02R)
Nice VTECH phone in backround!
Old Sep 18, 2004 | 06:36 PM
dmotoguy's Avatar
Default Re: (GreensleeperB16)
what do most people use to tune on a basically stock d16z6.. vafc?
can someone do a rundown of the parts needed?
gsxr work best for d-series?
Old Sep 19, 2004 | 08:09 AM
CRX_VTEC's Avatar
Default Re: (dmoto)
for d series any gsxr would be good. 600 750 1000.. they'll all work. Hyabusa for B-series. Also.. for K series too. (1 set made)
Old Sep 19, 2004 | 01:54 PM
Speedz's Avatar
Default Re: (CRX_VTEC)
couple pics showing brake booster space vs my itb stacks
Old Sep 19, 2004 | 05:51 PM
JUNcr-x's Avatar
Default Re: (Speedz)
lookin great..good work
