K24 block... how do you tell diffference between A2, A3 or A4?
Old Aug 30, 2004 | 02:05 PM
The_Head's Avatar
Default K24 block... how do you tell diffference between A2, A3 or A4?
Was just curious to know... I'm researching putting together a K24 Frankenstein setup and would like to get the TSX block. I don't want to get an Accord/CRV/Element block without knowing it.
I suppose on a longblock the valve cover (Honda vs. "A" Logo) would give it away. But you know how easily that can be switched by the shady...
TIA
Old Aug 30, 2004 | 04:18 PM
EtherGhost's Avatar
Default Re: K24 block... how do you tell diffference between A2, A3 or A4? (The_Head)
Check the stamp on the block.
Old Aug 30, 2004 | 07:33 PM
The_Head's Avatar
Default Re: K24 block... how do you tell diffference between A2, A3 or A4? (EtherGhost)
I suppose I should of been more specific, I'm talking JDM blocks...
I thought JDM blocks didn't have a last digit... like the DC-2R motor... it only says B18C.. How would you know which one K24 you had if it were JDM?
Old Aug 31, 2004 | 09:49 AM
Archidictus's Avatar
Unceasing Measure
Do a compression test maybe? I've got a K24A4 in my garage right now (along with a K20A2 because we're doing the same thing ) and it doesn't look any different than other K24's...aside from the Element/CRV K24 because those are light-truck motors and don't have a lot of the sensors and hoses and vacuum **** to deal with.
Old Aug 31, 2004 | 06:20 PM
kelphead's Avatar
Do u want to use the accord euro R block and if so it is a K20 motor and not a K24. The TSX is the K24.
Old Aug 31, 2004 | 11:31 PM
KillaB-'s Avatar
Default Re: K24 block... how do you tell diffference between A2, A3 or A4? (kelphead)
for a sure way to tell pick up honda tuning new issue labeled special K it has EVERYTHING about different k-series blocks and how to tell them apart.
Old Sep 1, 2004 | 12:27 AM
silver comet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kelphead &raquo;</TD></TR><TR><TD CLASS="quote">Do u want to use the accord euro R block and if so it is a K20 motor and not a K24. The TSX is the K24.</TD></TR></TABLE>
he said he wanted the TSX block
Old Sep 1, 2004 | 08:45 AM
aznboysrfr's Avatar
tsx has a metal intake manifold like the k20a/a2 ... others have plastic
Old Sep 1, 2004 | 09:16 AM
The_Head's Avatar
If you had TSX, CRV, Accord and Element Longblocks all next to one another, how could you tell the TSX longblock apart? What visual differences does it have? ...besides the valve cover
I do have the Honda Tuning issue with the article about the K's, it doesn't really say. It does mention all the K24's except the CRV have an EGR valve, so there's one clue.
Old Sep 1, 2004 | 11:23 AM
aznboysrfr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">If you had TSX, CRV, Accord and Element Longblocks all next to one another, how could you tell the TSX longblock apart? What visual differences does it have? ...besides the valve cover
I do have the Honda Tuning issue with the article about the K's, it doesn't really say. It does mention all the K24's except the CRV have an EGR valve, so there's one clue.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznboysrfr &raquo;</TD></TR><TR><TD CLASS="quote">tsx has a metal intake manifold like the k20a/a2 ... others have plastic
Old Sep 1, 2004 | 02:42 PM
nickzed20's Avatar
Default Re: K24 block... how do you tell diffference between A2, A3 or A4? (KillaB-)
that article was terrible... there wasnt anything that you couldnt already know from learning about these engines on honda-tech.
Old Sep 1, 2004 | 06:21 PM
JoeyBallzSI's Avatar
I've got a k24 block type s head and tranny plus ecu with clutch masters stage 3 clutch kit for sale let me know if you are interested.
Old Sep 1, 2004 | 06:46 PM
Kal's Avatar
Kal
Default Re: K24 block... how do you tell diffference between A2, A3 or A4? (aznboysrfr)
When I was getting my oil changed, I looked into the 04 Element's Engine bay. The IM was metal, not plastic. They changed it.
Old Sep 1, 2004 | 10:37 PM
FULLTHROTTLE's Avatar
Default Re: K24 block... how do you tell diffference between A2, A3 or A4? (Kal)
An easy way to tell if you have them sitting next to each other is the deck height on the 24 is easily 3/4 of an inch taller than the 20. Plus there are a few smaller insignificant differences but thats the main one.
Old Sep 2, 2004 | 12:31 PM
H22coupe's Avatar
Default Re: K24 block... how do you tell diffference between A2, A3 or A4? (FULLTHROTTLE)
Is there any diffence in the K24 short blocks from Accord, Element, or TSX aside from the pistons?
I've seen and read some of the difference in the heads but don't recall reading about differences in the bottom end aside from different compression ratios I believe.
Old Sep 2, 2004 | 02:02 PM
The_Head's Avatar
Default Re: K24 block... how do you tell diffference between A2, A3 or A4? (H22coupe)
The TSX has a better crank from what I've read, it can rev a bit higher. That's why I'm after it
Old Sep 2, 2004 | 05:46 PM
HotWheelz's Avatar
I have a TSX swap in my RSX and here's the pic to proove it, what do you want to know ?
FIRST in the country !
Old Sep 2, 2004 | 06:56 PM
Death-Site's Avatar
Default Re: K24 block... how do you tell diffference between A2, A3 or A4? (HotWheelz)
nice HotWheelz
Old Sep 3, 2004 | 09:43 PM
khunt0012's Avatar
Meat Robot Invisible
Default Re: K24 block... how do you tell diffference between A2, A3 or A4? (Death-Site)
Dude, nice honda badge...where can I get one...
Old Sep 4, 2004 | 11:09 PM
K20 EM2's Avatar
Default Re: K24 block... how do you tell diffference between A2, A3 or A4? (khunt0012)
ummmmm everywhere!!1 go on ebay
Old Sep 5, 2004 | 08:20 AM
goPHAST's Avatar
Default Re: K24 block... how do you tell diffference between A2, A3 or A4? (K20 EM2)
Pick up the latest issue of <U>Honda Tuning</U> October 2004. It has an article on how to do the K24 block/K20a2 head swap. Page 56. Answers a lot of questions. Also has a new Honda Fit that Mugen put a K20 in! Pretty cool!
Old Sep 5, 2004 | 09:18 PM
johnkimble's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khunt0012 &raquo;</TD></TR><TR><TD CLASS="quote">Dude, nice honda badge...where can I get one... </TD></TR></TABLE>
lol
Old Sep 9, 2004 | 11:10 AM
The_Head's Avatar
TTT
The initial question was really not answered... I never said anything about K20's... I understand a K24 is a bit taller than a K20 due to the longer stroke... I'm not asking about the K20 head swap on a K24... I'm not interested in buying anything...
How do you tell between a K24A2, K24A3, and K24A4 block? Not the head, just the block.
TIA
Old Sep 9, 2004 | 01:45 PM
DocSean's Avatar
Default Re: K24 block... how do you tell diffference between A2, A3 or A4? (goPHAST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goPHAST &raquo;</TD></TR><TR><TD CLASS="quote">Pick up the latest issue of <U>Honda Tuning</U> October 2004. It has an article on how to do the K24 block/K20a2 head swap. Page 56. Answers a lot of questions. Also has a new Honda Fit that Mugen put a K20 in! Pretty cool!</TD></TR></TABLE>
Haha, you're not really getting very far here are you??? Wish I had some answers for you man!
Old Sep 14, 2004 | 05:19 PM
alloutmotor's Avatar
i also notice that the pistons ect say ppX replace the x with another letter or number, wasnt paying it too much attention
hopefully i will be getting k24a block, some time this week or next , if anyone is intrested, hit me with pm
Rboosted717
May 8, 2003 08:33 AM
broliSI
Apr 5, 2003 06:06 PM
LshatchTurbo
Aug 30, 2001 06:51 AM
