Removing Driver's Seat
Old Aug 30, 2004 | 07:45 AM
Bandit74's Avatar
Default Removing Driver's Seat
I have a 1990 STD hatchback and was wondering what has to be unbolted, unscrewed, and/or unplugged to remove the driver side seat. I looked at it this morning and noticed, on the front side, that there were two bolts that bolted into the floor at an angle. I didn't check the backside.
Old Aug 30, 2004 | 07:53 AM
Footwork's Avatar
Default Re: Removing Driver's Seat (Bandit74)
there are 4 bolts plus possibly a harness that needs to be unplugged (seat belt light indicator)...other than that it's super easy.
Old Aug 30, 2004 | 07:54 AM
XrcR6's Avatar
Yes, those two in the front. Two more in the rear (that are probably under plastic covers that slide off). And disconnect the 2-wire wiring harness under the seat that detects whether you have the seatbelt connected. Not very hard at all.
Old Aug 30, 2004 | 07:55 AM
hatchinprogress's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bandit74 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1990 STD hatchback and was wondering what has to be unbolted, unscrewed, and/or unplugged to remove the driver side seat. I looked at it this morning and noticed, on the front side, that there were two bolts that bolted into the floor at an angle. I didn't check the backside.
</TD></TR></TABLE> there are4 bolts one on each corner(12mm) and a plug under the seat(unplug it) and thats it
Old Aug 30, 2004 | 08:23 AM
Bandit74's Avatar
Great - thanks, gang.
Old Aug 30, 2004 | 09:03 AM
lunchboxEF91's Avatar
what are you going to replace the seat with?
Old Aug 30, 2004 | 09:04 AM
Bandit74's Avatar
By the way, does anyone have a 1990 Civic STD vinyl driver side seat they're not using?
Old Aug 30, 2004 | 11:45 AM
Bandit74's Avatar
/bump
Old Aug 30, 2004 | 11:48 AM
Default Re: (Bandit74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bandit74 &raquo;</TD></TR><TR><TD CLASS="quote">By the way, does anyone have a 1990 Civic STD vinyl driver side seat they're not using?</TD></TR></TABLE> i do but im in cali and the seat is torn (sorry)
01celica_gts
Jan 17, 2017 12:31 AM
89sicivic
Mar 9, 2007 04:57 PM
jgrif08
Oct 23, 2006 06:08 PM
soberstan
12
Oct 22, 2004 12:01 PM
Griff
Apr 15, 2004 08:25 PM
