No pressure in gas tank
Old Aug 30, 2004 | 05:57 AM
Layziebtnh055's Avatar
Default No pressure in gas tank
i know there is a hole in the top of my tank somwhere because it leaks when its full, but would no pressure in the gas tank cause a low idle and make the car shake bad at idle??
Old Aug 30, 2004 | 05:51 PM
Default Re: No pressure in gas tank (Layziebtnh055)
bump
Old Aug 30, 2004 | 06:27 PM
NFM_Dm's Avatar
it made my car sputter at high rpms and have a really random idle somtimes high sometimes low.
Old Aug 30, 2004 | 06:50 PM
SloVXHatch's Avatar
If you know there's a hole, replace it! I'd hate for you to end up on your 10 o'clock news. "Local person injured in gas tank explosion." Fix it now!
Old Aug 31, 2004 | 08:08 AM
tgreaves's Avatar
I personally dont think it would hurt the idle.. The evac system puts a vacuum on the gas tanks for emissions reasons so you might not pass emissions but I would guess thats all that would come from this..
How big is the hole.. You could probably fix it with some jb weld..
Old Aug 31, 2004 | 08:15 AM
Home Skillet's Avatar
How did you get a hole in the top of your gas tank?
Old Sep 1, 2004 | 05:31 AM
Default Re: No pressure in gas tank (Home Skillet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Home Skillet &raquo;</TD></TR><TR><TD CLASS="quote">How did you get a hole in the top of your gas tank?</TD></TR></TABLE>
I have no clue, i ca fill my tank up and iut wont leak while the car is just sitting there, but if i drive around for a minute and come back it leaks for about 5 minutes then tops
Old Sep 1, 2004 | 06:37 AM
VashTheStampede's Avatar
No tears. Only dreams, now.
He's from Ohio guys... **** rusts.
I just replaced my tank about 3 days ago. Go to Advance Auto, order a new tank, straps, and buy some rubberized anti-rust coating, and some primer. Take it to a cheap shop, and have them fix it. No vacuum isn't a problem either.
tonydize21
Jun 28, 2011 02:26 AM
luisrblue
Mar 24, 2009 08:56 PM
GI8U2racing
17
Mar 26, 2007 01:27 PM
adaml2nv
Jun 6, 2004 04:50 AM
SLOW4drINTEG
Nov 7, 2003 08:36 PM
