zc question... (dohc)
this is kinda a stupid question, but what all you need to put a zc motor in a 91 civic dx hatch? i dont mean tools, do i need a new tranny? new ecu? will the old tranny bolt up to it? do i need new mounts? i know how to do the work, i just want to make sure i get all the right parts
http://hometown.aol.com/nosajuf/nosajuf2.htm
http://dmoore.com/crx/zc.htm#What Did It Cost?
those should help answer almost all your questions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ubercerealkiller »</TD></TR><TR><TD CLASS="quote">this is kinda a stupid question, but what all you need to put a zc motor in a 91 civic dx hatch? i dont mean tools, do i need a new tranny? new ecu? will the old tranny bolt up to it? do i need new mounts? i know how to do the work, i just want to make sure i get all the right parts</TD></TR></TABLE> you can use your tranny (but i would get an si tranny if you dont have one? you should get an ecu but i think you can use your stock ecu(you will just run lean) you dont need new mounts, but you will have to change your wiring from dpfi to mpfi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote"> you can use your tranny (but i would get an si tranny if you dont have one? you should get an ecu but i think you can use your stock ecu(you will just run lean) you dont need new mounts, but you will have to change your wiring from dpfi to mpfi</TD></TR></TABLE>
You are correct but he will need a new ecu since his dpfi ecu can only control two injectors while the zc has four. So he will need a new ecu and also he will need to convert his wiring to run mpfi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic »</TD></TR><TR><TD CLASS="quote">
You are correct but he will need a new ecu since his dpfi ecu can only control two injectors while the zc has four. So he will need a new ecu and also he will need to convert his wiring to run mpfi.</TD></TR></TABLE> see thats what i've been told (im running an integra ecu) but people say the dpfi ecu will work you will just run lean
I am 100% positive the dpfi ecu will not work otherwise why would everyone do the mpfi swap when they swap in an mpfi engine. Running an Si(PM6) ecu will generally run the ZC a little lean.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCZCCRXSi »</TD></TR><TR><TD CLASS="quote">Im special, I'm using the PG7 too, works fine on my DOHCZC <~ plz refer to it as that so the SEARCH function can be used.. - Darrell</TD></TR></TABLE> or dohc works but just zc is too short
DarknessInside51
May 31, 2004 05:02 PM
Jonhren
14
Aug 5, 2003 08:54 PM
