HOLy Crap My MoonRoof dont Open
Old Aug 30, 2004 | 12:12 AM
TurboTeG4's Avatar
Default HOLy Crap My MoonRoof dont Open
Well in my 94 teg today when I hit the open switch the motor just whines and then I hit the close switch n it moves a little. Aack What do I do, do I buy another motor from acura and take off the headiner and install?? Is it easy and do I need to take anything off besides the headliner to replace the motor?
Old Aug 30, 2004 | 12:35 AM
JFG Kevin's Avatar
Default Re: HOLy Crap My MoonRoof dont Open (TurboTeG4)
haha..buddy, relax, your rubber around your moonroof is probably dried up, so spray some wd40 on it and try it again.
Modified by aznstyler119 at 8:39 AM 8/31/2004
Old Aug 30, 2004 | 03:04 AM
jdm_cars's Avatar
I would say try give it a whirl with the manual lever. pop off the cap and use the tool to open and close it a few times, then try again.
if it still doesn't work, might be your motor or might be the cable is stuck.
Old Nov 10, 2004 | 11:26 PM
TurboTeG4's Avatar
Where is the location to insert the manual moonroof crank on a 94 teg??????I cant find it
Old Nov 11, 2004 | 05:02 AM
95integraLS's Avatar
Mine went out a long time ago but i never use it anyway so it doesnt bother me.
Old Nov 11, 2004 | 09:01 AM
vain's Avatar
Default Re: HOLy Crap My MoonRoof dont Open (95integraLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95integraLS &raquo;</TD></TR><TR><TD CLASS="quote">Mine went out a long time ago but i never use it anyway so it doesnt bother me.</TD></TR></TABLE>
thanks for the input
did you try regreasing the rails?
Old Nov 11, 2004 | 09:24 AM
Default Re: HOLy Crap My MoonRoof dont Open (vain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vain &raquo;</TD></TR><TR><TD CLASS="quote">
did you try regreasing the rails?</TD></TR></TABLE>
nope...i never used it when it worked so i have no reason to try to fix it.
Old Nov 11, 2004 | 12:52 PM
vain's Avatar
lol. that was directed towards the originator of the thread.
Old Nov 11, 2004 | 12:57 PM
my bad.
Old Nov 11, 2004 | 01:06 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
It is the round plug over the rear seat. Use a quarter to take that out, and I believe you use the lug nut wrench to open or close it. Check in your owners manual. It should be there.
Old Nov 14, 2004 | 10:04 AM
TurboTeG4's Avatar
Default Re: HOLy Crap My MoonRoof dont Open (marsbike)
Well I put a alan wrench in there but it felt like I was forcing it so I stopped, What Gives?? My roof just stopped working all of a sudden wtf could it be, I wonder how much acura charges to fix it.
Old Nov 14, 2004 | 10:16 AM
G-bonic's Avatar
Hijacked
try changing the relay 1st under ur steering wheel and see wut happen.. this happened to me before and i just change the relay it work back to normal... if it doesnt do anything i got the moonroof motor for sale let me kno....
Old Nov 14, 2004 | 12:09 PM
gotskimmilk's Avatar
Default Re: HOLy Crap My MoonRoof dont Open (Stock_LS)
hahaha hope a bird doesn't crap in ur car, good luck w/ it
Old Nov 20, 2004 | 10:32 AM
TurboTeG4's Avatar
Default Re: HOLy Crap My MoonRoof dont Open (gotskimmilk)
When changing the motor , does the glass need to come off like it says in the helms?
Old Nov 21, 2004 | 01:48 AM
weedman's Avatar
good luck with it, had same problem
Old Nov 21, 2004 | 02:01 AM
MaskedAP1's Avatar
Default Re: HOLy Crap My MoonRoof dont Open (weedman)
its time to move on, SHAVE IT.. the lighter the better.. racers dont need sunroof
Old Nov 21, 2004 | 08:18 AM
SmurfDA's Avatar
From: I live in a town with Boston traffic, mass, united states
Default Re: HOLy Crap My MoonRoof dont Open (MaskedDC4)
try pushing up on the sunroof when your opening it, sometimes they need persausion
Old Nov 21, 2004 | 03:37 PM
WRTEG's Avatar
use the manual release, use something to turn it if you don't still have the release tool, mine was acting the same way, used the manual release and once i did that it has been working fine since, must have been something stuck in the tracks
Old Nov 21, 2004 | 04:17 PM
Mythias's Avatar
on my old LS, I had the same problem... I used the manual release tool, and it worked, however had some hesitation. So I cleaned the tracks, and applied a small amount of grease, and it worked fine without any problems for over a year(when I got rid of her).
Old Nov 21, 2004 | 06:44 PM
TurboTeG4's Avatar
Default Re: HOLy Crap My MoonRoof dont Open (mythias)
IT get stuck and binds, how the hell can it just go out of track like that, wtf. I went to the glass shop and I think I dont want them to do it as they would rip me off.
Old Nov 21, 2004 | 08:14 PM
JDAN's Avatar
do you hear the 'buzz' of the sunroof engine when you push the switch?? if so then teh motor is probably fine, it just sounds like the roof is stuck. Try pushing in it while pushing the open switch. Also try what aznstyler119 said and spray some lubricant onto the rubber gasket around the roof.
Old Nov 21, 2004 | 09:25 PM
TurboTeG4's Avatar
Default Re: (JDAN)
I try turning it with the manual wrench and it moves a little bit and then gets stuck, I know its not the seal on top getting stuck, I tried pushing on it.
Old Nov 28, 2004 | 11:25 AM
TurboTeG4's Avatar
Ahhhh the Day of GlorY
Well on advice from sim shadeee I forced my moonroof open with the manual tool. At the point of binding which is just a little open from close I forced it just a little, not too rough and it snapped out and I got it too open.
Make a long story short, theres these tracks that move back and forth and is held back by a spring, on each side. Well on close examination the track on the right side did not have the spring attatched and the track was slightly off the rails near the spring mount. I stuck a flat head screwdriver in there and got it back on the tracks. I also lubed all the rubbers with O-Ring lubricant, wd40 would probably make the rubber expand so dont use that.
My moonroof is working FlaWlessLy now, I went to 2 upholstry shops, and was this close to start removing the headliner. Thank god I pm'd Slim Shadeee else I probably would do something stupid like take off the headliner.
Yep this is a good ThanksGiving WeekEnd After All
Old Nov 28, 2004 | 12:30 PM
Seedc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">Ahhhh the Day of GlorY
Glad you got the bitch open.
mugenhatchie
Sep 8, 2006 11:32 PM
ImportechPerformance
11
Dec 13, 2004 11:39 AM
iridebiketrials
Feb 26, 2004 08:36 PM
Chrislow
15
Feb 22, 2004 09:39 PM
