'94 EX Brake Shimmy - Common?
Old Aug 29, 2004 | 10:58 PM
civicsg's Avatar
Default '94 EX Brake Shimmy - Common?
Looking to buy a '94 EX. This thing shimmies "dramatically" when braking hard to very hard (like coming off the freeway) but seems to be fine in all "more or less" gentle applications. I feel that in an emergency stop, you gotta REALLY hold on to the steering wheel, or lose it.
Seller says has done this for all 160,000 miles since he purchased it new, claims dealer states it's not unusual.
Can anyone shed some light on this? Seems pretty "un-Honda-like".
Old Aug 29, 2004 | 11:03 PM
The_Todd's Avatar
Farts in the shower
Default Re: '94 EX Brake Shimmy - Common? (civicsg)
My guess would be warped rotors...very common for accords.
Check the following:
tire pressure
alignment
balancing of tires
pads/rotors
Old Aug 29, 2004 | 11:12 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: '94 EX Brake Shimmy - Common? (VRDrvr)
My fellow ***** is correct.
Warped rotors is the most likely explaination. The owner probably has bad driving habits that have caused that problem on a consistent basis, even when he gets new rotors.
Old Aug 29, 2004 | 11:16 PM
civicsg's Avatar
Default Re: '94 EX Brake Shimmy - Common? (rochesterricer)
So what "bad driving habits" warp the disks?
Or... Do I have to brake like a chauffeur to be happy with this car?
Modified by civicsg at 12:29 AM 8/30/2004
Old Aug 29, 2004 | 11:27 PM
ShaunRR's Avatar
HT White Ops
Community Builder
The main habit is "riding the brakes", meaning resting your foot on the brake pedal.
Old Aug 30, 2004 | 09:07 AM
aZnAcCoRd02's Avatar
yes ***** 001 and 019 are speakin the truth, its very common for accords to have warped rotors, just have them resurfaced or if its that bad replaced, another way to warp rotors easy is gettin watter on them after they are hot it can bend in a hot second
Old Aug 30, 2004 | 09:11 AM
lance351's Avatar
my 96 was the same way when i got it last month i just replaced pads and rotor now its fine try that
Old Aug 30, 2004 | 09:31 AM
Bitpicker1011's Avatar
Default Re: '94 EX Brake Shimmy - Common? (lance351)
My 94 EX also would shimmy when braking hard. I replaced the rotors with after market ones and about two months later they started pulsing. But now only when I brake easy - when I brake hard they are fine. Is that still a sign of warping or is there another reason for the pulsing? I probably should have bought a more expensive rotor. Is there a good after market rotor that works well or do I need to get genuine Honda (if I can save up the cash)?
405hp
Honda Civic (2006 - 2015)
14
Nov 2, 2009 05:14 AM
lamboextreme
Dec 30, 2007 11:19 AM
JDMflavor_EJ
12
Dec 5, 2007 07:51 PM
Econo'Box
Jun 6, 2007 10:03 PM
psunumber1
Jan 29, 2002 02:05 PM
