what engine swap is easiest for my 91 civic hatch with the 1.5L?
Old Aug 29, 2004 | 05:27 PM
madbass1's Avatar
Default what engine swap is easiest for my 91 civic hatch with the 1.5L?
I just got a new honda civic hatch project car and i need to add some performance in it. I thought that i could get a turbo but then i was told that its would blow up my engine since it has about 150,000 on it.
So what i wanted to know is what engine should i get that uses the same stock eninge mounts? It has a stock 1.5L dx engine.
please help!!!!
Old Aug 29, 2004 | 05:30 PM
NFM_Dm's Avatar
Default Re: what engine swap is easiest for my 91 civic hatch with the 1.5L? (madbass1)
any obd0 you could get a d series and use the current tranny and harness that you already have d16z6, d15 vtec, or dohc zc sounds good.
Old Aug 29, 2004 | 05:33 PM
SloVXHatch's Avatar
DOHC ZC. You can get one for under 600. Just get an ECU, do some wiring, and you're set.
Old Aug 29, 2004 | 05:51 PM
LAMA's Avatar
Default Re: what engine swap is easiest for my 91 civic hatch with the 1.5L? (SloVXHatch)
if you want to go turbo, you could do sohc zc and then turbo that.
its supposed to boost very well
Old Aug 29, 2004 | 07:53 PM
Bandit74's Avatar
Would a SOHC vtec work with a 1990 STD hatchback? Also, would I have to get a new tranny since mine is a 4-speed trany?
Old Aug 29, 2004 | 07:55 PM
Change's Avatar
Default Re: (Bandit74)
you will have to swap to mpfi and you will deffinitly need a 5 speed. the si tranny is popular.
Old Aug 29, 2004 | 07:58 PM
hatchinprogress's Avatar
Default Re: (pSI civic)
go with the dohc zc
Old Aug 31, 2004 | 11:03 AM
madbass1's Avatar
ok i found a jdm zc dohc engine and tranny combo. it includes:
Engine
Transmission 5 Speed
ECU
All Mounts
Disterbuter
Starter
Alternatur
A/C Compresser
Power Steering Pump
All Sensors
Intake Manifold
Exaust Manifold
what i want to know is is that all i need?
Old Aug 31, 2004 | 11:06 AM
quicksol95's Avatar
if you car is a dx or std
you need to convert the harness to mpfi
99jdem18L
32
Apr 22, 2006 08:00 AM
MANDO6669
41
Apr 2, 2006 12:34 PM
x91civichatch
16
Oct 15, 2005 08:23 PM
ninjapanda
May 25, 2005 10:02 PM
91_hatch_si
Jan 9, 2003 06:24 PM
