Mini Me SOHC build up... (what to do next)
Old Aug 29, 2004 | 04:09 PM
EGRhatch's Avatar
Default Mini Me SOHC build up... (what to do next)
So I am kind of in a bind here, and I am not sure what cam or valves to go with because there is not too much info out there... all I have read about is skunk2... some people say they are great, and some say they are shitty...
I am leaning towards skunk2 because that seems to be the only thing on the market that I have come across... but what about other companies... I've heard little about the zex cam... info would be great onanything...
I have a stock Z6 head that I am going to take up to the machine shop and get PnP one day... how far can/should I go with the port job??
I have read that the stock Z6 springs are strong enough to rev up to 9K is this safe though?
so far on the motor it is a stock bottom D15b7 with a Z6 head, Skunk2 I/M with H22 throttle body, skunk2 camgear, and skunk2 chipped P28...
the next thing I am looking at upgrading is the valves and ret. (possibly springs) but anything else you guys think I should do next or within the near future?? thanks a lot
-Brandon
Modified by EGRhatch at 10:37 PM 8/29/2004
Old Aug 29, 2004 | 07:36 PM
EGRhatch's Avatar
Default Re: Mini Me SOHC build up... (EGRhatch)
anyone??
Old Aug 29, 2004 | 07:41 PM
CivicVX94's Avatar
i don't have much imput besides I would replace the valve springs before the valves,I would think they are more likely to cause problems when reving high.
Also if your planning on getting a PnP and new valves I would go with a 3 angle valve job(or whatever it's called nowadays lol) and a little over bore and some oversize valves you'll should gain some power from doing that
Old Aug 29, 2004 | 08:09 PM
EGRhatch's Avatar
Default Re: Mini Me SOHC build up... (CivicVX94)
cool, now where can I find some oversized valves... as in who makes them so I can start searching...
right now, I'm putting 125whp... with what i;ve got...
Old Aug 30, 2004 | 02:57 PM
CivicVX94's Avatar
i think ferrea (sp?) does have oversized valves but do a search on ebay or something. I'll look too and post the links once i find em
Old Aug 30, 2004 | 02:59 PM
CivicVX94's Avatar
http://cgi.ebay.com/ebaymotors...33621
kinda pricey but he says just tell him if you want oversized
*edit* i just read "manley" makes oversized valves also
Modified by CivicVX94 at 12:22 AM 8/31/2004
Old Aug 30, 2004 | 03:08 PM
Darkane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGRhatch &raquo;</TD></TR><TR><TD CLASS="quote">I have read that the stock Z6 springs are strong enough to rev up to 9K is this safe though?
Modified by EGRhatch at 10:37 PM 8/29/2004</TD></TR></TABLE>
Even if the springs could rev that high A cam that would make Power that high would most likely cause the stock springs to Bind which would be very very bad!! Spring bind just means when the spring does not have enough "room" or compression to allow the valve to drop the amount of lift the cam is producing well you know what happens. The valves becomes solid but there is still more lift and you wreck havoc. hope that helps
Old Aug 30, 2004 | 03:26 PM
CivicVX94's Avatar
https://honda-tech.com/zerosearch?id=5326947
alright I searched and there seems to be mixed feelings about oversized valves. If your staying NA then it seems to be stay stock size but turbo or nitrous oversized is a good thing but it requires more headwork than one would think and you would need to replace you valve seals and such.
Old Aug 31, 2004 | 06:35 AM
EGRhatch's Avatar
thanks for all the info man, helped out a lot... anyone else that can be as helpful as 94vx??
Old Aug 31, 2004 | 01:57 PM
EGRhatch's Avatar
more info??
Old Aug 31, 2004 | 07:22 PM
CivicVX94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGRhatch &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the info man, helped out a lot... anyone else that can be as helpful as 94vx??</TD></TR></TABLE>
No prob, I'm just glad to help out.
And a bump for you
Old Aug 31, 2004 | 08:06 PM
spoonef's Avatar
bump for a good guy and Dseries
Old Sep 1, 2004 | 04:01 AM
EGRhatch's Avatar
Default Re: Mini Me SOHC build up... (spoonef)
thanks man, how the new hatch comming along??
Old Sep 1, 2004 | 10:39 AM
D15powerd's Avatar
For the head: Have them do a mild to good port job, you don't need to sacrifice velocity and it's on the street anyways. Get the 3-angle valve job and if you can get 1mm oversized valves. Check out the ZEX/Comp Cams lineup for the z6, the cam has some of the best lift and duration on the market. I picked my #59300 cam for only $230, beats the hell out of what Skunk is asking. Get ZEX's matching springs and retainers to boot as well. That should make for a pretty sick SOHC head. The springs would be the most important upgrade in my book, nothing sucks more than max'ing out your springs or valve float.
If you don't already have a good header on there i would do that, either a Bisimoto header if you have the cash or a DC 4-1 if you're cheap like me.
Here are some good sites for you to check out for parts:
http://www.exospeed.com
http://www.dh-racing.com
http://www.theoldone.com
Old Sep 1, 2004 | 11:33 AM
EGRhatch's Avatar
Default Re: Mini Me SOHC build up... (D15powerd)
thanks a lot man, that really helped out... now I'll have somethign to do in between classes tonight...
Old Sep 2, 2004 | 09:59 AM
spoonef's Avatar
Im loving my new hatch get some vids please
Old Sep 2, 2004 | 05:12 PM
EGRhatch's Avatar
when the new pistons go in, I'm gonna wax the biznatch for the first time and I will try to get down to the track to take some video's
skunk2.com
Performance
20
Nov 12, 2009 03:20 PM
PhantomLord
May 15, 2007 11:03 AM
1hotintegra
Jun 16, 2003 08:05 AM
