Aftermarket Oil Coolers - How do you know what size to use?
Old Dec 5, 2001 | 06:07 AM
GReddyB18C's Avatar
Default Aftermarket Oil Coolers - How do you know what size to use?
The article on the Hybrid board uses an 11" x 8" x 1.5" 48 row cooler, Andrew here on HT uses an Earl's 14 row cooler, XS Engineering uses a 10.75” x 7.00” x 2.00” 19 row cooler for their kits, and I've seen other sizes used as well.
So, how do you properly size an oil cooler to your particular application? I'm building a high compression (12.35:1) N/A motor that will be in a daily driver that sees lots of track time, plus I live in hot and humid Houston, TX (traffic city) -> I'm sure an oil cooler would be very beneficial.
Any insight on this topic would be extremely helpful. TIA.
-Shawn
[Modified by GReddyB18C, 9:09 AM 12/5/2001]
Old Dec 5, 2001 | 12:14 PM
davew's Avatar
Default Re: Aftermarket Oil Coolers - How do you know what size to use? (GReddyB18C)
the best way is to find out what your oil temp is and then caluclate how much cooler you would like it to be, and then use the appropriate size cooler. don't be so quick to assume that you need one. I know mane dedicated honda track cars that run high CR in hot climates and never have oilt temp problems. and cold oil is just as bad as hot oil...
dave w
Old Dec 5, 2001 | 12:17 PM
jeff652's Avatar
I was hitting 280 degrees during lapping sessions.
I put in a Mocal 24 row cooler and now I stay between 150-155 on he street and ~180ish on the track. Worth every penny . . .
[Modified by jeff652, 1:17 PM 12/5/2001]
Old Dec 5, 2001 | 12:53 PM
austrian type-R's Avatar
Default Re: Aftermarket Oil Coolers - How do you know what size to use? (jeff652)
Does´nt the typr-R hasa stock oil cooler? I think it is cooled from the coolant. The oil cooler is located where the oil filter is. What is the optimal oil temp to have. Please tell me in Celsius!
Old Dec 5, 2001 | 01:04 PM
Big Phat R's Avatar
Default Re: Aftermarket Oil Coolers - How do you know what size to use? (austrian ITR)
Try this here for those of you who cannot handle the math of C/F conversion...
The stock oil cooler is fine for daily driving - but sub-par for hard track use.
[Modified by Big Phat R, 2:06 PM 12/5/2001]
Old Dec 5, 2001 | 01:20 PM
Default Re: Aftermarket Oil Coolers - How do you know what size to use? (Big Phat R)
Old Dec 5, 2001 | 01:35 PM
cobalt's Avatar
New User
What does installing an aftermarket oil cooler entail?
TIA... -Andie
Old Dec 5, 2001 | 01:45 PM
jeff652's Avatar
Default Re: Aftermarket Oil Coolers - How do you know what size to use? (CarbotechAndie)
This is a good example of one way to do it: (similar to my setup)
http://hybrid.honda-perf.org/tech/oilcooler/index.html
Old Dec 5, 2001 | 01:55 PM
yoshi234's Avatar
I shoot brides
how does one go about changing oil? wont some of the oil stay in the line and cooler?
-y
Old Dec 5, 2001 | 01:59 PM
jeff652's Avatar
Default Re: Aftermarket Oil Coolers - How do you know what size to use? (yoshi234)
Remove bumper and open system at lowest point. For me I remove the cooler and drain it and the lines.
Good thing I rarely drive the car and 3k miles is several months apart . . .
Old Dec 5, 2001 | 02:06 PM
Jimmy L's Avatar
I read somewhere that the use of an aftermarket oil cooler will lower your oil pressure and a high flow oil pump is nessisary. Is this true? Does anyone have one installed and have a pressure gauge?
Old Dec 5, 2001 | 02:33 PM
Crossett's Avatar
Where can I buy that?
*edit*
where did you put the battery? pics?
[Modified by Crossett, 5:34 PM 12/5/2001]
Old Dec 5, 2001 | 02:49 PM
quikrpm'z's Avatar
does anyone have a pic of the stock itr oil cooler, and would i be able to use it on my car? 96rs
Old Dec 5, 2001 | 02:50 PM
_unknown_'s Avatar
Looks like a Canton/Mecca oil filter. I am thinking about one as well.
http://www.cmfilters.com
Very Important!!! For those who are using an remote oil cooler, you should run a thermostat in line with the oil cooler. You want to get the oil to proper operating level.
HTH
[Modified by spoonek9, 3:57 PM 12/5/2001]
Old Dec 6, 2001 | 08:18 AM
garagespecial
Guest
Posts: n/a
Default Re: Aftermarket Oil Coolers - How do you know what size to use? (spoonek9)
if you want a bad *** oil cooler.....get Greddy IMO....works charms in my hybrid no problems yet
Old Dec 6, 2001 | 09:56 AM
davew's Avatar
Jeff...280 is pretty high. you may want to check your timing, etc and see what is causing you to produce so much excess heat. Yes the oil cooler is now taking the heat, away but that is more curing the symptoms than any problems.
-dave w
Old Dec 6, 2001 | 10:14 AM
jeff652's Avatar
Default Re: Aftermarket Oil Coolers - How do you know what size to use? (davew)
Yeah timing is at 19 degrees. My motor makes power all the way to 23 degrees, but I need to get a J&S to run it that advanced (plus 100 octane)
wantboost
Feb 24, 2013 02:13 AM
flangemastermike
Mar 4, 2008 03:35 PM
mityVR6
Feb 17, 2003 11:39 PM
Steve91
17
Jul 12, 2002 10:43 PM
Batoutahell
Jul 9, 2002 12:29 PM
