$700 what to do with it
Old Aug 29, 2004 | 02:45 PM
civicefdx's Avatar
Default $700 what to do with it
i have a stock 91 civic hatch with a usda d15b2. what should i invest in?>
Old Aug 29, 2004 | 02:50 PM
Skunk.Werks's Avatar
Default Re: $700 what to do with it (civicefdx)
Pick up a d16a6 and drop it in. Also convert to MPFI
B16 CRX's Avatar
Give the money to me, Its not worth investing in a SOHC DOHC
eda6's Avatar
Brakes/suspension. Or keep saving and do a swap.
Old Aug 29, 2004 | 03:03 PM
AgentJam's Avatar
Default Re: $700 what to do with it (eda6 hb)
a set of P29 pistons in an A6 would get you well into the 14's in less than that...
Old Aug 29, 2004 | 03:30 PM
91crx2004's Avatar
Default Re: $700 what to do with it (Skunk.Werks)
wut is MPFI..my CRX si says PGM-FI..wuts the different from MPFI and PGM-FI..
Old Aug 29, 2004 | 04:11 PM
viper_2_4's Avatar
Default Re: $700 what to do with it (91crx2004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91crx2004 &raquo;</TD></TR><TR><TD CLASS="quote">wut is MPFI..my CRX si says PGM-FI..wuts the different from MPFI and PGM-FI..</TD></TR></TABLE>
Multi Port fuel injection, your CRX Si does have it, it is essentially a fuel injector for each cylinder, rather than Dual Point, which has 2 injectors for all 4 cylinders......MPFI is a type of PGM-FI.....
Old Aug 29, 2004 | 04:45 PM
mar778c's Avatar
Community Builder
Community Influencer
Depends on the tranny you have in the car. If it is a 5-speed tranny, then swap a ZC or SOHC Vtec long block. If it is a 4-speed, then save up more money for a full swap.
Old Aug 29, 2004 | 05:59 PM
sm00thk0zz's Avatar
Default Re: $700 what to do with it (B16 CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16 CRX &raquo;</TD></TR><TR><TD CLASS="quote">Give the money to me, Its not worth investing in a SOHC DOHC </TD></TR></TABLE> That statement
With the amount of money you spend in DOHC you can have ur single cam bad ***. Turbo set up or monster build....
Plus, what kinda DOHC SWAP w/ mounts can he get for 700 bucks?
Old Aug 29, 2004 | 06:02 PM
Change's Avatar
Default Re: $700 what to do with it (sm00thk0zz)
i vote for a d16a6 swap.
**** Raising eXcitement? hell yeah... every honda is a crx in that case...
Old Aug 29, 2004 | 06:19 PM
SloVXHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sm00thk0zz &raquo;</TD></TR><TR><TD CLASS="quote">
Plus, what kinda DOHC SWAP w/ mounts can he get for 700 bucks?</TD></TR></TABLE>
Um, a DOHC ZC will run you about 700, give or take.
Old Aug 29, 2004 | 06:21 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
id be all over the a6 with p29 pistons. that motor will have some *****
Old Aug 29, 2004 | 06:43 PM
hahagasdcrx's Avatar
Default Re: (91siredrex)
Pick up a hooker and have a buddy video tape the session then post it on the net. Make your money back ten fold.
Actually i would hold onto the money and save some more to put a turbo on there or a swap.
Old Aug 29, 2004 | 07:04 PM
Malgerus's Avatar
Default Re: (hahagasdcrx)
D16A6 swap.
If you knew a bit more about these cars (no offense), then I'd try and pick up a sohc VTEC... might take a bit more than 700, but well worth it.
Old Aug 29, 2004 | 07:06 PM
Change's Avatar
Default Re: (Mr. S)
i've seen d16z6's go for $400-$900.
Old Aug 29, 2004 | 07:38 PM
civicefdx's Avatar
i could do a mini me for like 400 bucks, maybe a little more with a y8 head, would that be as good as swaping in a SOHC vtec or are there downsides that the full swap doesnt have?
Old Aug 29, 2004 | 07:58 PM
AgentJam's Avatar
Default Re: (civicefdx)
just the .1 liter that a y8 or z6 block would have, easier and cheaper though !
Old Aug 29, 2004 | 08:01 PM
civicefdx's Avatar
usda d15 block w/ y8(maybe z6) head, MPFI, p29 pistons? good setup?
Old Aug 29, 2004 | 08:05 PM
Proper's Avatar
Default Re: $700 what to do with it (SloVXHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloVXHatch &raquo;</TD></TR><TR><TD CLASS="quote">Um, a DOHC ZC will run you about 700, give or take.</TD></TR></TABLE>
You are getting raped if you pay that much. I've seen more than a few complete(eng. trans) DOHC zc's go for 500 or less.
I vote A6 build. you can probably get an A6 for like $100.00 Then you got $600 left for an Si or ZC tranny and some go fast parts
Old Aug 29, 2004 | 08:08 PM
daidilus's Avatar
Block
D15B7
Head
D16Y7
Pistons
P29 (USDM D16A1 88-89)
Head Gasket Thickness
D15B7 - D16A6
Piston-To-DecK Height
OEM D15B7 D16A6
Compression
11.65669009634531
Displacement
1493.4071802601438
http://www.knology.net/~jediklc/D.htm
then strip your car out, tint the back windows as dark as law allows, get a OBD-0 PR3, go to http://pgmfi.org, ask if anyone has a program that deletes an O2 sensor, then if they can send you one, find a local electrician/jeweler person that can remove and replace chips. get pictures and show him what chip needs to be moved. cheap...pow pow powa wheels..ohh yeah...learn how to drive a stick well if you don't know how to.....
Modified by daidilus at 11:30 PM 8/29/2004
Old Aug 29, 2004 | 08:32 PM
The ZC's Avatar
Default Re: (daidilus)
100's of Vtec and Type R stickers....
Suspesion / Handling are good ways to start.
Old Aug 29, 2004 | 08:45 PM
s2k_al's Avatar
Default Re: (The ZC)
With that money you should buy a DOHC ZC. And your gona need a PG7 ecu(88-89 integra ecu). And i have one for sale .Hit me up if you get the DOHC ZC.
Old Aug 29, 2004 | 09:03 PM
b16_madman's Avatar
Default Re: (c_rex88)
save it for sus. and tires
Old Aug 30, 2004 | 12:25 AM
EeeJayEight's Avatar
Default Re: (B16_madman)
build ur suspension...get some shocks/springs for like 400...then just either save the rest or do mini-me and mpfi swap...
Old Aug 30, 2004 | 12:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicefdx &raquo;</TD></TR><TR><TD CLASS="quote">i have a stock 91 civic hatch with a usda d15b2. what should i invest in?&gt;</TD></TR></TABLE>
not to flame but isnt usda the meat inspectors? i know u meant usdm but i just caught it...suspension all the way
