13 inch performance tires?
From: spinning DnB till your head explodes,jersey/philly
i just put a set of 88 prelude rims on my crx and im wondering if they make a performance tire with a lower profile in a 13 inch size. i painted the mesh part black and left the aluminum lip. just seeing is they make a performance/autox tire for that size rim. as u know its a 13x5 size rim. thanks
Try looking at the manufacturer's websites. Here's a few:
http://www.hoosiertire.com
http://www.goodyeartires.com
http://www.kuhmousa.com
http://www.michelinman.com
http://www.toyo.com
Or, how about some tire retailers:
https://ustireoutlet.com
https://www.edgeracing.com
http://www.tirerack.com
Most of them will let you search for a specific size. Try doing the work yourself next time, it taint dat harrrd.
http://www.toyo.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean O’Gorman »</TD></TR><TR><TD CLASS="quote">R-comps yes, for street use, no.</TD></TR></TABLE>
Sumitomo HTR-Z and HTR-200s (or something like that) both come in a 13" size that are pretty decent. Both are street tires.
Check tirerack. All the info is there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91siredrex »</TD></TR><TR><TD CLASS="quote">i just put a set of 88 prelude rims on my crx and im wondering if they make a performance tire with a lower profile in a 13 inch size. i painted the mesh part black and left the aluminum lip. just seeing is they make a performance/autox tire for that size rim. as u know its a 13x5 size rim. thanks</TD></TR></TABLE>
bolt two of your wheels together, and mount up some of these:
http://www.tirerack.com/tires/...R+200
175/50HR13 - $40
185/60HR13 - $35
195/60HR13 - $39
Or if you want all out performance at expense of treadwear, you can run full tread Kumho Ecsta V700's or Toyo RA1's. Both can be run on the street, but don't expect to get more than 5,000 miles on them.
175/50HR13 - $40
185/60HR13 - $35
195/60HR13 - $39
