how big of a difference? honda parts vs autozone parts
Old Aug 29, 2004 | 10:05 AM
hatchinprogress's Avatar
Default how big of a difference? honda parts vs autozone parts
ok my problem is i have oil in my spark plugs (i've found out it's valve cover rings) so now i need to get a valve cover gasket set. of course its sunday so i cant get parts from honda but i want to to this today(sunday) so how much of a difference is autozone gasket kit vs. honda gasket kit???? and yes i know honda should be better but by how much?
Old Aug 29, 2004 | 10:17 AM
Monkey Fing a Coconut's Avatar
Default Re: how big of a difference? honda parts vs autozone parts (hatchinprogress)
at least for axles and thermostats its a big difference, search the honda website, some parts dept at honda dealerships are open on sundays, not many but there are some
Old Aug 29, 2004 | 10:25 AM
Default Re: how big of a difference? honda parts vs autozone parts (twistedbydezign)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign &raquo;</TD></TR><TR><TD CLASS="quote">at least for axles and thermostats its a big difference, search the honda website, some parts dept at honda dealerships are open on sundays, not many but there are some</TD></TR></TABLE> no parts are open on sundays here
Old Aug 29, 2004 | 10:33 AM
91AccordSE's Avatar
Dude, Autozone sells Felpro gaskets. They are the best aftermarket gaskets bar none. I don't like to promote the Zone, but I will this time. Go get a felpro gasket kit, and get-er done.
Old Aug 29, 2004 | 11:16 AM
supercreed2002's Avatar
Default Re: how big of a difference? honda parts vs autozone parts (91AccordSE)
Well, everything I bought from AutoZone has worked just fine and tends to be at least half the price cheaper then the Parts Dept. (Exp- Radiators: Local Rad. Shop=$125 AutoZone=$108 and Honda Parts Dept.=$203). Need I say more?
Caleb
Old Aug 29, 2004 | 11:23 AM
madd's Avatar
Default Re: how big of a difference? honda parts vs autozone parts (supercreed2002)
when it comes to timing belts, etc..... Honda OEM &gt; *
Old Aug 29, 2004 | 11:26 AM
Default Re: how big of a difference? honda parts vs autozone parts (madd)
thanks peeps
Old Aug 29, 2004 | 11:57 AM
AngryTroll's Avatar
Are you sure you know why there is oil on your spark plugs? Usually, it's not the four round gaskets in the valve cover that cause the problem.
Old Aug 29, 2004 | 11:58 AM
AngryTroll's Avatar
Default Re: how big of a difference? honda parts vs autozone parts (AngryTroll)
...and buy OEM parts whenever possible. If you look online, you can find Honda parts close to the same price as aftermarket parts. My prices are even better.
Old Aug 29, 2004 | 01:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AngryTroll &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you know why there is oil on your spark plugs? Usually, it's not the four round gaskets in the valve cover that cause the problem.</TD></TR></TABLE> any one have another idea? what could the problem be??
Old Aug 29, 2004 | 02:57 PM
ttt
Old Aug 29, 2004 | 03:05 PM
91AccordSE's Avatar
Hey Troll, I would like to know what other problems you have seen with these, that will cause the oil to puddle up on the outside of the spark plugs? Since the 4 round rubber seals are made to keep the oil out of that area of the spark plug hole recess, I am not sure what else is there for seperation.
Old Aug 29, 2004 | 03:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91AccordSE &raquo;</TD></TR><TR><TD CLASS="quote">Hey Troll, I would like to know what other problems you have seen with these, that will cause the oil to puddle up on the outside of the spark plugs? Since the 4 round rubber seals are made to keep the oil out of that area of the spark plug hole recess, I am not sure what else is there for seperation.
</TD></TR></TABLE> i would like to know also...what else could it be??
Old Aug 29, 2004 | 03:19 PM
madd's Avatar
there are upper spark plug tube seals that come with your valve cover gasket set and there are lower spark plug seals located underneath your rocker arms
Old Aug 29, 2004 | 03:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madd &raquo;</TD></TR><TR><TD CLASS="quote">there are upper spark plug tube seals that come with your valve cover gasket set and there are lower spark plug seals located underneath your rocker arms </TD></TR></TABLE> but does it sound like it could be from the bottom?? cuz i dont wanna do the bottom (i dont know that much yet) but i dont mind the valve cover. but know people are sayin that it might be from the bottom??
Old Aug 29, 2004 | 03:48 PM
AngryTroll's Avatar
It's the spark plug tube O-RINGS. Somewhere, I have pictures that show exactly where the o-rings are located. When I find them, I'll post them for you.
Old Aug 29, 2004 | 03:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AngryTroll &raquo;</TD></TR><TR><TD CLASS="quote">It's the spark plug tube O-RINGS. Somewhere, I have pictures that show exactly where the o-rings are located. When I find them, I'll post them for you.</TD></TR></TABLE> but is that the top or bottom???
AngryTroll's Avatar
Old Aug 29, 2004 | 04:04 PM
AngryTroll's Avatar
The picture is the bottom of the rocker arm carrier. If you look closely, you will see four black o-rings in their grooves. These o-rings will be as hard as a rock, and they are the cause of oil leaking on your spark plugs.
It's an extremely easy repair. Once the valve cover is removed, all you need is a 10mm and 12mm socket to remove the rocker arm assembly.
Old Aug 29, 2004 | 05:58 PM
91AccordSE's Avatar
My bad Troll! I forgot all about those. Not sure how I did either, considering I just had mine off about 2 weeks ago.
By the way, I would recommend getting these seals from honda. The ones that came in my aftermarket engine kit were round rubber o-rings (instead of square seals). They did not stay in position very well.
akunamatta
Jun 26, 2007 01:41 PM
hatchinprogress
Aug 29, 2004 04:11 PM
