t3/t4e on b16s-what power?
t3/t4e turbo will be going on my car soon running approx 15psi, if u have a t3/t4e please post up what power your car is throwing out at how much boost. it will give me a fair idea on what to expect with mine, would be gratefull if you could post setup info or any dynos.
wanna also get a fair idea on whats the max i can push with this turbo
thanks
thanks
Drag 3 kit which comes with a T3/T04B made 370whp 21psi, befor eon stock motor made 243whp 276ft-lb torque, 18 psi before Hondata made 320whp 256 ft-lb. FOund out later was supposed to be a T3/T04 with Super V trim compressor wheel, it was actually a T04B S trim SMALLEST wheel made, then Stage 1 turbine instead of what was supposed to be a Stage 3 wheel. Still made good power for what it was.
I have a t3/to4e from the drag 3 kit... made 347whp @13.7psi with a blown HG... but the b16 was bored/stroked to a 2.0L, and I don't know if and how much power was lost because of a **** load of water went through the motor...
^^^you guys are running some good numbers on low boost^^
makes me seem my target is more and more achievable
----Lets have some more numbers setups/dynos---
thanks
thanks
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1 vtec »</TD></TR><TR><TD CLASS="quote">^^^nice numbers what boost you running^^^</TD></TR></TABLE>
13-14psi
The car made over 250whp off the .45bar spring. The final tune @ 307whp is very conservative and hardly any timing in the motor.
13-14psi
2000 civic sI
9:1 cp pistons, eagle rods
81.5mm bore
Revhard kit with a
50 TRIM T3/T04E
.60/.63 A/R, Stage 5 wheel (or a precision sc50)
780cc injectors
hondata s200b
3" catless exhaust after 2.5" dp
14.7psi = 298whp/ 212 lbs/ft
a/f = 11.5 accross the board
81.5mm bore
Revhard kit with a
50 TRIM T3/T04E
780cc injectors
hondata s200b
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed »</TD></TR><TR><TD CLASS="quote">Drag 3 kit which comes with a T3/T04B made 370whp 21psi, befor eon stock motor made 243whp 276ft-lb torque, 18 psi before Hondata made 320whp 256 ft-lb. FOund out later was supposed to be a T3/T04 with Super V trim compressor wheel, it was actually a T04B S trim SMALLEST wheel made, then Stage 1 turbine instead of what was supposed to be a Stage 3 wheel. Still made good power for what it was.
My car made 238whp on 13lbs. with the same kit. It was 8.8:1 b16.
t3/to4b with .48 exhaust
needless to say im gonna **** my pants going from that... to a 9.8:1 gsr motor and gt35e/t4
</TD></TR></TABLE>My car made 238whp on 13lbs. with the same kit. It was 8.8:1 b16.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowhitecrx »</TD></TR><TR><TD CLASS="quote">b16 stock bottom t3/t4 running only 4 psi due to ignition and no EMS yet laid down 261 whp and 160 ft lbs... </TD></TR></TABLE>
wow, on only 4psi? im hoping mine makes that much at 7psi
