Who's got an Excedy clutch?
Old Dec 4, 2001 | 10:12 PM
MrFatBooty's Avatar
Default Who's got an Excedy clutch?
There seems to be a dearth of information on Excedy clutches out there. Right now I'm pretty much set on the ACT HDSS. And then there's this deal at clutchcityonline.com for the Excedy organic-disk clutch for $250. What's the holding capacity and pedal pressure like? Also, the 3-puck "cerametallic" is the same price as the HDSS. What kind of a workout for my clutch foot can I expect with that?
I have a cable clutch so I'd try to not get something that has too heavy of a pressure plate.
Old Dec 5, 2001 | 01:14 PM
MrFatBooty's Avatar
Default Re: Who's got an Excedy clutch? (MrFatBooty)
ttt
Old Dec 5, 2001 | 01:25 PM
jdmotorsports's Avatar
the excedy is stock pedel pressure and it hold a 98 non-vtec with aem/dc headers/exhaust and 75wet shot of n2o on slicks and nitto 555's. feels realy good to me when i drove it.
Old Dec 5, 2001 | 02:07 PM
IntegraGSR23's Avatar
Default Re: Who's got an Excedy clutch? (jdmotorsports)
I am in the market for a clutch. Where can I get a good deal on a kit? Excedy, ACT, Clutchmaster, etc.. Which is worth the money and can give the best bang for the buck?
[Modified by IntegraGSR23, 3:07 PM 12/5/2001]
I am in the market for a clutch. Where can I get a good deal on a kit? Excedy, ACT, Clutchmaster? Which is worth the money and can give the best bang for the buck?
Old Dec 5, 2001 | 02:10 PM
D-SPEED's Avatar
Default Re: Who's got an Excedy clutch? (IntegraGSR23)
booty-
ive got an exedy in my 94 GSR..the organic one....the pedal is NOT stock stiffness...my friend just got a ACT heavy duty, and my pedal is stiffer than his. I dont know if this corresponds to the grabbing capacity...just to give you some reference. It grabs pretty solid overall.
Old Dec 6, 2001 | 05:58 AM
alexboy's Avatar
Default Re: Who's got an Excedy clutch? (D-SPEED)
Exedy makes great clutches i have one in my ls fairly stock pedddle feel. Grabs regular on normal shifting but grabs strong on fast shifting
Old Dec 6, 2001 | 06:14 AM
Slick GS-R's Avatar
Default Re: Who's got an Excedy clutch? (alexboy)
I agree, three cheers for exedy, here.........here
Old Dec 6, 2001 | 06:20 AM
FSTASNTZ's Avatar
Exedy is a good clutch. I have run one for the last year.
As for the HDSS and the Exedy, the Exedy has a softer pedal, IMO. As for the 3 puck, I am not sure of any benifits with it. It is rated at the same clamping force as the full face kit from Exedy...
Jason
Old Dec 6, 2001 | 08:34 AM
Project X's Avatar
Default Re: Who's got an Excedy clutch? (FSTASNTZ)
I too have an Exedy 3-puck race clutch and its 4.1 kg chromoly flywheel. This combo is very good. It grabs very well and the pressure is slightly more stiffer than the ITR one. I will give it !
Old Dec 6, 2001 | 10:47 AM
BoM's Avatar
BoM
Default Re: Who's got an Excedy clutch? (Project X)
http://www.clutchcityonline.com
Old Dec 6, 2001 | 11:43 AM
MrFatBooty's Avatar
Default Re: Who's got an Excedy clutch? (BoM)
I know WHERE to get em, just don't have much info on em.
Full-face organic disk sounds good. And I now have realized that the reason a search didn't turn up much is because I spelled it "Excedy" instead of "Exedy."
Old Dec 6, 2001 | 12:37 PM
I just visited that site and their Excedy kit does not come with a throwout bearing. Whereas, an ACT kit does come with one. What exactly does the throwout bearing do? What is it's function? TIA
Old Dec 6, 2001 | 07:21 PM
MrFatBooty's Avatar
"Effective December 1, 2001, all Exedy racing clutch kits come with a pressure plate, clutch disc, release bearing, and an alignment tool. Shipping on Exedy racing cltuch kits is FREE!"
Release bearing = throwout bearing. It actuates the pressure plate.
You have another bearing in there called both the flywheel bearing and the pilot bearinf. It lets the clutch and flywheel spin. You can get a new pilot bearing for like 30 bucks. Which still puts Exedy way cheaper than an ACT HDSS which you can get for $383 plus shipping from optauto.com.
Old Dec 6, 2001 | 08:05 PM
nfn15037's Avatar
No, a release bearing isnt the same as a throwout bearing. The T/O bearing goes on the tranny input shaft, and the release bearing goes in the flywheel.
Old Dec 6, 2001 | 09:05 PM
MrFatBooty's Avatar
Default Re: Who's got an Excedy clutch? (nfn15037)
Goddammit there are so many bearings in the clutch. I do know for sure that the release bearing actuates the pressure plate. Is the throwout bearing the same as the clutch housing bearing then?
The latest from clutchcityonline.com:
"Also, 08-800 will include Exedy racing pressure plate, Exedy organic disc, NACHI release bearing, pilot bearing, and alignment tool. Plus shipping will be FREE."
[Modified by MrFatBooty, 6:07 AM 12/7/2001]
Old Dec 7, 2001 | 09:13 AM
Mike K's Avatar
Get with the program. Release bearing IS throwout bearing. Same way people call the 'front main seal' an 'oil pump seal', or 'front crankshaft seal'..
the pilot bearing goes on the flywheel.
Old Dec 7, 2001 | 09:25 AM
I visited the site agagin - Check this out:
http://www.clutchcityonline.com/special.htm
http://www.clutchcityonline.com/raci...ec/08-800A.htm
Check both of those sites out and compare them. It mentions it on one and does not on the other. I called them and it DOES include it. I am in need of one so I ordered one, and it's on the way.
Charlie @ Clutch City
[Modified by IntegraGSR23, 10:27 AM 12/7/2001]
Old Dec 7, 2001 | 09:27 AM
Slick GS-R's Avatar
check out http://www.coximport.com great service with killer prices
Old Dec 7, 2001 | 10:06 AM
Default Re: Who's got an Excedy clutch? (Slick_GS-R)
The Exedy clutch is more expensive there, how you figure they have killer prices?
Old Dec 7, 2001 | 10:57 AM
Slick GS-R's Avatar
well, they usually have groupbuys running and they hooked me up for a cheap price.........
Old Dec 7, 2001 | 12:14 PM
nfn15037's Avatar
Thanx for the clarification, Mike
Old Dec 8, 2001 | 02:23 PM
clutchcityonline's Avatar
Release bearing is Throw Out Bearing.
Just wanna let everyone know that when you purchase any Exedy racing clutches, you will receive the following (everything you will need to a clutch job):
1. Exedy racing pressure plate
2. Exedy organic/cerametallic disc
3. Release bearing (Throw-out bearing)
4. Pilot bearing (this bearing gets installed on either crank or flywheel)
5. Alignment tool
Those are basically all you will need to do a clutch job unless flywheel is being changed. In case if you are using stock flywheel, make sure flywheel gets resurfaced by a machine shop (DO NOT buzz-grind) using correct spec (most Civics have 0.065" recessed flywheel where most Integras, Si, and Vtec Del Sol have 0.112" stepped flywheels.
[Modified by clutchcityonline, 1:27 AM 12/11/2001]
Old Dec 9, 2001 | 08:37 AM
teg90rs's Avatar
Default Re: Who's got an Excedy clutch? (clutchcityonline)
Is the Exedy organic clutch good enough for 6 psi boost daily driver?
Old Dec 9, 2001 | 09:13 AM
Slick GS-R's Avatar
Default Re: Who's got an Excedy clutch? (teg90rs)
it most definitely is strong enough to hold that power. the clutch itself can hold up to 350 HP.............
