Justed installed a new clutch. Know I loosing gears. why?
Old Aug 28, 2004 | 08:06 PM
dpine's Avatar
Default Justed installed a new clutch. Know I loosing gears. why?
I just installed a new clutch in my brothers car last night. The tranny had a slight 4th gear grind but now it has gotten worse. Also all the other gears were fine until I took it to the store to get some gas this afternoon. I try to put in reverse and all it does is grind. I tries putting it into 1st, 2nd, 3rd, 5th before I tried putting it into reverse but it still ground. Its a J1 tranny. Can someone enlighten me on what the problem could be. I am pretty sure whats wrong with 4th(syncro). I have put about 75 miles on the new clutch.
thanks
Old Aug 28, 2004 | 08:49 PM
Louie B.'s Avatar
Default Re: Justed installed a new clutch. Know I loosing gears. why? (dpine)
sounds like the clutch is adjusted too loose and not fully disengaging. Tighten the adjustment **** a little
Old Aug 28, 2004 | 09:46 PM
Mr_CRX's Avatar
Default Re: Justed installed a new clutch. Know I loosing gears. why? (thumpu77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumpu77 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the clutch is adjusted too loose and not fully disengaging. Tighten the adjustment **** a little</TD></TR></TABLE>
That's what I was thinking too.
Old Aug 29, 2004 | 07:17 AM
dpine's Avatar
I have adjusted it. That sucker is as tight as I can get it.
Old Aug 29, 2004 | 08:35 AM
Louie B.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpine &raquo;</TD></TR><TR><TD CLASS="quote">
I have adjusted it. That sucker is as tight as I can get it.</TD></TR></TABLE>
that's not good! it shouldn't be that tight. something's definately not right then.
Old Aug 29, 2004 | 08:49 AM
dpine's Avatar
Any cable tranny guru's out there?
Old Aug 29, 2004 | 09:12 AM
BiG Chris's Avatar
better take it back apart maybe the clutch bolts have come loose
Old Aug 31, 2004 | 05:30 PM
dpine's Avatar
Default Re: Justed installed a new clutch. Know I loosing gears. why? (BiG Chris)
update: I took my clutch cable and bracket off me b series motor and transfered it over to my brothers car. Problem Fixed. I didn't even have to adjust anything. It seems that my brothers car had a d series cable and a modified d series bracket. My question is I have no ideo what come off my car, so do I need to get a 90-93 integra cable and tranny bracket?
thanks
civicsi18
Transmission & Drivetrain
Aug 16, 2008 08:11 AM
JDM_SOHC
Apr 26, 2006 02:08 PM
KrispyKreme
22
Jan 10, 2005 11:57 PM
redINTEGRAdriver
Dec 13, 2004 03:54 PM
CRXed
May 12, 2004 02:24 PM
