gsr axles
I have a gsr set-up in my 96 hatch. My axles are bad and I bought Driveshaftshop axles to replace them with. Never changed axles before so I will need to follow a manual probably. I only have my civic manual, can I follow that or do I need to go out and get an Integra manual?
i dont think the manual from acura would help you with disassembling the front arms to pull the axle out. But for tools, make sure you have a 32mm, 17mm, 14mm, prybar, and a ball joint splitter if you choose to separate your upper ball joint like i do. Im sure there's a guide somewhere on the net to swap out axles. If everything comes out easily...then i would guess you'd have both done in under an hour. If you were local i'd give you a hand.
The civic manual is pretty much the same as a integra manual as far as pulling out the axles. The b series swap uses a intermediate shaft and 2 axles......whereas the d series uses a long axle and short axle with no intermediate shaft. besides that its pretty much the same
