Eg radiator.
I installed it the other day and love it. No over heating problems and on top of that my car runs a little bit cooler too. The only bad thing is i i had to chop a hole in my cf hood.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 »</TD></TR><TR><TD CLASS="quote">how did you make the bracket?</TD></TR></TABLE> by the looks of his hood i dont think there is/was a bracket
well my sis' camera is out of batteries, so i'll explain it. I took some aluminum and bent it and kept test fitin it, then drilled out a big hole to go over the **** atop the eg rad. then drilled a hole big enough for a bolt to go through the alumin and the lil hole almost right in front of the **** on the eg rad, then bend it just right, and it'll fit perfect, holds it tight. And u could of just leaned your rad. back a lil bit instead of cuttin the hood up, but a lil late for that
Thanks and my fan would not allow me to lean my radiator back. My fan was melted on the edge because of the header. Its really cramped
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 »</TD></TR><TR><TD CLASS="quote">How would i do this and the reason there is a hole is so my hood will close.</TD></TR></TABLE>
lol, I know that's the reason.
I said fill that hole in as a 5 side box/cube.
Take some fiberglass mat and some resin and fill in the gaps between the top of the hood and the support area. You can still leave the 'hole' that the radiator cap fits in.
ben_eg6
Dec 18, 2005 11:40 PM
my Oem radiator works perfectly fine and it is cool it sits at 1/4 of the temp
