help me wire my Gauge's so i stop looking like a damn ricer!!!
Old Aug 28, 2004 | 03:56 PM
Shakes's Avatar
space cadet
Default help me wire my Gauge's so i stop looking like a damn ricer!!!
ok, i am pissed. hole in the firewall is bigger, gauges are mounted and now i cant figure out a place to wire the damn gauges up.
i need a 12v constant (after ignition), ground and one that hooks to dash lights.
the only place i have found to put them in one of the connectors on the internal fuse box, but there is no constant 12v source i can tap into there so they only work when the lights are on.
where do you have yours?
Old Aug 28, 2004 | 05:34 PM
96*j-spec*lUde's Avatar
Default Re: help me wire my Gauge's so i stop looking like a damn ricer!!! (Shakes)
on my gauges i have them connected into the internal fuse box, and i used the fuse for "foglights". i have no foglights on my car...so that worked for me, constant power running into it, and you dont need to have the lights on. you just gotta look at all your fuses, pick one you dont use (it would be there for add on options when the car is first purchased). and drop the lines straight down behind the dash. or if it's a 4th gen, you can look under your dash, there is a plug that comes out, and theres a spot that you can run wires through your firewall into your engine bay, then just go to the battery if you want. hope this helps a little bit, sorry i couldnt give more info..
Old Aug 28, 2004 | 08:46 PM
FlaN.'s Avatar
Doug, you damn ricer.
Old Aug 28, 2004 | 09:26 PM
Shakes's Avatar
space cadet
Default Re: (FlaN.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlaN. &raquo;</TD></TR><TR><TD CLASS="quote">Doug, you damn ricer. </TD></TR></TABLE>
im gunna steel the gauges out of your car, then ill have a full sweep gauge cluster in blue
Old Aug 28, 2004 | 10:42 PM
TimeRacer's Avatar
Default Re: (Shakes)
Really depends on where you want your gauges and how long of a wire that you want to run. Personally (due to my gauge pod) I have everything tapped off the clock power as I figured that the clock would not draw much at all by itself so I won't be popping fuses. It works and powers 3 gauges. I've also tapped off (on Civics and Integs) the cruise control button to power indiglo gauge clusters. You can really just tap off anything that gets a constant on power and headlight power and ground it where ever you want. But the best way is for the fusebox, I didn't have enough wire on hand (oops!) when I did my gauges so I tried off the clock. It works and I haven't touched it since.
Old Aug 29, 2004 | 01:29 AM
@ries's Avatar
Just wait til you come out here to San Diego... I'll help you wire them bitches up. Just supply the
Old Aug 29, 2004 | 08:44 AM
FlaN.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">
im gunna steel the gauges out of your car, then ill have a full sweep gauge cluster in blue </TD></TR></TABLE>
my gauges are amber.
Old Aug 29, 2004 | 08:55 AM
Shakes's Avatar
space cadet
Default Re: help me wire my Gauge's so i stop looking like a damn ricer!!! (@ries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries &raquo;</TD></TR><TR><TD CLASS="quote">Just wait til you come out here to San Diego... I'll help you wire them bitches up. Just supply the </TD></TR></TABLE>
lol, not waiting that long. John (Jagen92) is coming over today and we are going to work on them. i HATE wiring and he loves it. so all i gotta do is give his girlfriend some chocolate and i will be allowed to utilize him all day on my car
Chris: damnit! i coulda sworn they were blue.
Old Aug 29, 2004 | 01:41 PM
Qveon's Avatar
Constant 12v is a 12 gauge white wire under the dash
Ground is anywhere on metal
Gauge illumination is Red/Black behind your radio. or 18 guage red/black wire in driver's kickpanel.
Old Aug 29, 2004 | 02:41 PM
flip1199's Avatar
Default Re: help me wire my Gauge's so i stop looking like a damn ricer!!! (Qveon)
if u get a test light and check your incar fuse box you'll find the 12v constant and 12v lighting. they are there
Old Aug 29, 2004 | 04:39 PM
Jagan'92's Avatar
You damn ricer. I may have done your work for you but I taxed the hell outta your computer, huh. Stop going to all those **** sites and you won't have this problem anymore.
We tried to wire the gauge lights to the dimmer wire (red/white), but then the gauges got brighter when the rest of the lights got dimmer. Oops. So they're just hooked to the lights now (at the dimmer switch).
Old Aug 29, 2004 | 07:37 PM
Shakes's Avatar
space cadet
Default Re: help me wire my Gauge's so i stop looking like a damn ricer!!! (Jagan'92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jagan’92 &raquo;</TD></TR><TR><TD CLASS="quote">You damn ricer. I may have done your work for you but I taxed the hell outta your computer, huh. Stop going to all those **** sites and you won't have this problem anymore.
We tried to wire the gauge lights to the dimmer wire (red/white), but then the gauges got brighter when the rest of the lights got dimmer. Oops. So they're just hooked to the lights now (at the dimmer switch).</TD></TR></TABLE>
hahaha, i had to slick the hard drive and reload everything.
here is the pic of the gauges. they are extreemly bright!
Old Aug 29, 2004 | 08:28 PM
Kal's Avatar
Kal
looking good.
Old Aug 29, 2004 | 09:45 PM
revlimitx04's Avatar
Default Re: help me wire my Gauge's so i stop looking like a damn ricer!!! (Kal)
I used the wiper fuse under the dash, works fine, not riced out at all, very clean install, just put the power wire on the fuse peg of the wipers, theyre always on when car is on.
julioboostamante
Nov 4, 2011 03:33 PM
dark_reverie
Jan 26, 2009 11:22 AM
WhySpeed
Jan 23, 2007 05:28 PM
civiceg500
10
Dec 29, 2004 03:14 PM
jnet
Dec 20, 2004 05:31 PM
