So I suppose there's no easy way to replace the rear tranny mount...
Old Aug 28, 2004 | 02:37 PM
travis's Avatar
Default So I suppose there's no easy way to replace the rear tranny mount...
I have the motor out, but it looks as though there's no getting to the rear bolt without removing the back crossmember. Say it isn't so! The bolts by the green arrows are out, but it's the back bolt (red arrow, but you can't see it in this picture) that's going to be the problem.
Old Aug 28, 2004 | 03:07 PM
Beyond Imagination's Avatar
Default Re: So I suppose there's no easy way to replace the rear tranny mount... (travis)
i removed my rear tranny mount by taking out the front two bolts. then i used a hammer and gently tapped the mount over to the side where i was able to use a socket wrench on it.
Old Aug 28, 2004 | 03:23 PM
kid-honda's Avatar
Default Re: So I suppose there's no easy way to replace the rear tranny mount... (Beyond Imagination)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beyond Imagination &raquo;</TD></TR><TR><TD CLASS="quote">i removed my rear tranny mount by taking out the front two bolts. then i used a hammer and gently tapped the mount over to the side where i was able to use a socket wrench on it.</TD></TR></TABLE>
thats what I always do.
Old Aug 28, 2004 | 03:42 PM
travis's Avatar
Tyson directed me to this: http://crx.honda-perf.org/foru...light
A u-joint and a really long extension did the trick. Best of all, I could also tighten it back down for the new mount. Thanks guys.
chrisff521
May 19, 2010 06:06 AM
travis
Aug 28, 2004 09:53 PM
Nerologic
11
Jun 21, 2004 12:39 PM
xerox445
17
Nov 13, 2003 07:14 PM
