radiator flushing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKS2000 »</TD></TR><TR><TD CLASS="quote">has anyone done a radiator flush on there s2000? if so how do you do it? is there a bolt like the oil pan on the radiator or do you need to suck it out wit a vacum</TD></TR></TABLE>
there's a drain plug on the radiator, not hard to flush, same thing as flushing any other car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKS2000 »</TD></TR><TR><TD CLASS="quote">where is the plug? do i have to take panals off of the car to get to it? and what kinda antifreeze should i use and how much of it do i put in the radiator</TD></TR></TABLE>
remove the underpanel plastics, and you can't miss the drain plug, it's white. You can flush the coolant quicker, by removing a coolant hose near the intake manifold and siphoning out the coolant via an extension hose.
