How stiff is the clutch pedal with a *sprung* 6 puck clutch?
Old Aug 28, 2004 | 10:54 AM
SuicideSlide's Avatar
Default How stiff is the clutch pedal with a *sprung* 6 puck clutch?
So how stiff will my clutch pedal be with a sprung 6 puck clutch setup? I havent decided on brand but will more than likely be upgrading to this due to a blown stock clutch.
Old Aug 28, 2004 | 11:41 AM
kun3racer's Avatar
Default Re: How stiff is the clutch pedal with a *sprung* 6 puck clutch? (Tur*bLu)
being sprung or 6 puck doesnt have anything to do with pedal stiffness. its the pressure plate you need to look into, not the disc.
Old Aug 28, 2004 | 11:44 AM
2fast4u831's Avatar
I'm really 2slow
its hard kinda like your brakes
Old Aug 28, 2004 | 11:45 AM
-Gambit-'s Avatar
its as hard as one gets on viagra, i mean ummmmm ....never mind
Old Aug 28, 2004 | 11:27 PM
JdmEg6Hybrid's Avatar
i have an act 6 puck disk and an act heavy duty pressure plate and it is stiff. it gives my leg an work out
Old Aug 28, 2004 | 11:42 PM
nocturnaldragon's Avatar
Default Re: How stiff is the clutch pedal with a *sprung* 6 puck clutch? (JdmEg6Hybrid)
It all matters on the pressure plate but i also have an Act heavy duty pressure plate in my car and its still as hell!
Old Aug 28, 2004 | 11:54 PM
Default Re: How stiff is the clutch pedal with a *sprung* 6 puck clutch? (nocternaldragon)
Go with Act or Exedy!!!! I got one of each in both me cars
Old Aug 29, 2004 | 10:13 AM
Default Re: How stiff is the clutch pedal with a *sprung* 6 puck clutch? (Geeky_Gambit)
yummm...viagra....
Old Aug 29, 2004 | 10:16 AM
AsianMullet's Avatar
Yep, pressure plate makes the difference. Go to ACT's site to see how much more pedal pressure each pressure plate is
Old Aug 29, 2004 | 12:21 PM
TallAssFilipino's Avatar
Default Re: How stiff is the clutch pedal with a *sprung* 6 puck clutch? (EKchump)
So, what's a deal or good price for a decent ACT pressure plate?
Old Aug 29, 2004 | 01:21 PM
Default Re: How stiff is the clutch pedal with a *sprung* 6 puck clutch? (TallAssFilipino)
depends which pressure plate you want. Heavy Duty is probably good for strip and street use.
Old Aug 29, 2004 | 01:25 PM
drewbie's Avatar
excedy hypersingle
dunked dc
Apr 9, 2011 11:06 AM
JFG Kevin
May 10, 2004 04:25 PM
GraphiteAccord
Feb 12, 2003 10:56 AM
T3EMSI
Jul 22, 2002 07:46 PM
