replaceing rear brake pads
use a c-clamp, or a tool designed to push the piston back in all way. it works better than using a screw driver and trying to twist the piston back in. there's a "bump" (for lack of a better word) on the brake pad that fits into the groove on the piston. make sure the piston is aligned right... if it isn't, simply use a large flathead and twist the piston so that it fits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd »</TD></TR><TR><TD CLASS="quote">Quote, originally posted by torps »
wax the car.... will increase performance a little i think.
well id like to increase my fuel economy as well... and wax woudl help with that.
BWUAHAHHAHAHAHAHAHAHAHAH.... i can't believe this guy was serious...
.</TD></TR></TABLE>
I wonder if he took me seriously when I told him that since tires are the part that rotate he need to armour all all four tires to get the best friction free turning and thusly about 1/10th faster in the 1/4mile
.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stew Pidasso »</TD></TR><TR><TD CLASS="quote">USe a pair of needle nose pliers and grab the slot in the the caliper. You have to "screw" the rear pistons back in...</TD></TR></TABLE>
Correct, screw the piston back in, not push.
BB4lude
Feb 11, 2008 01:47 PM
kaiba
Jun 13, 2005 07:41 PM
