1990 civic 4 door help me find the right motor
Old Aug 28, 2004 | 01:51 AM
curt801's Avatar
Default 1990 civic 4 door help me find the right motor
Thinking of swapping a motor into my girlfriends car need help deciding witch one to go with. I am thinking about a d15 vtec. any suggestions.
Old Aug 28, 2004 | 03:10 AM
Limited S.L.I.P.'s Avatar
i did a mini-me then a sohc vtec in mine..
Old Aug 28, 2004 | 06:57 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (Limited S.L.I.P.)
D15B should bolt right in with an MPFI swap... I'd go with an Si tranny though.
Old Aug 28, 2004 | 07:25 AM
wtsexton's Avatar
My gf wants a CRX with a b-series engine but it has to be auto. Blah not much info on such swaps.
Old Aug 28, 2004 | 08:13 AM
Jester88Si's Avatar
Default Re: (wtsexton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtsexton &raquo;</TD></TR><TR><TD CLASS="quote">My gf wants a CRX with a b-series engine but it has to be auto. Blah not much info on such swaps.</TD></TR></TABLE> I think an auto swap could be done but you would have problems with the transmission mount and you'll probably have to add a few wires to the harness. If you don't wanna do all that you better teach her how to drive with a manual tranny.
Old Aug 28, 2004 | 08:56 AM
curt801's Avatar
what other mods besides mpfi would i need to do for a d15 vtec.
Old Aug 28, 2004 | 09:33 AM
vtecn8ive's Avatar
Default Re: (b1788crx)
wire up vtec and is it going to be obd-0/I?
Old Aug 28, 2004 | 10:06 AM
I8ayellowcrayon's Avatar
Go ahead and either wire the harness for OBD1, or get a conversion harness. Thats the only way to get VTECs full potential.
What swap would be best? What does she want to do with it? Daily driver, but wants it to go when she gets on it? D15B would probably be the best, if not the D16Z6. I wouldn't do a mini-me for a daily driver unless the block was near perfect. Just something about all of that pieced together Mickey Mouse crap. Z6 would be easier to get, and in most cases cheaper than the D15B...
Also, something to think about, JDM engines (D15B) have been sitting in warehouses for a few years... Gaskets go bad, seals go bad... I've replaced the rear main seal, valve cover gasket, cam seals, and head gasket on my ZC because they were ALL leaking. If you could get a Z6 out of an EX/Si that was rear ended or something it would be a lot better.
1990civic4door
14
Apr 19, 2010 02:25 AM
jdmstockeg6
17
Sep 28, 2007 08:33 PM
BOOSTEDP5
Oct 17, 2005 07:38 AM
jdm236
11
May 16, 2004 04:14 PM
streetlegal gocart
14
Nov 16, 2003 11:24 AM
