How to build 200whp ITR Motor
Old Aug 27, 2004 | 11:58 PM
integrasi's Avatar
Default How to build 200whp ITR Motor
Currently I have stock internal itr. What do i need to do in order to produce 200whp.
currently I have icebox, arm, comptech header & skunk2 exhaust, 70mm throttlebody, hondata im gasket.
previously dynoed @ 182whp.
Old Aug 28, 2004 | 12:02 AM
jiahanhao's Avatar
Default Re: How to build 200whp ITR Motor (integrasi)
you need AT LEAST (not a guarantee) cams and engine management...
I made 190 w/ skunk2 stage 1's, hondata s200, and I/H/E, on a dyno dynamics dyno, which usually reads lower...
also remember, every dyno is different, as is every car, so there are no guarantees for xxx hp, and should be used more as a measure of improvement than as bragging rights.
Old Aug 28, 2004 | 12:49 AM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
All motor Forum
Old Aug 28, 2004 | 12:53 AM
Misfit's Avatar
you finally changed your signature... but it still sucks.
what do you currently have done to your car?
are you asking this question because you are drunk?
did you bother to use the search function?
Old Aug 28, 2004 | 01:10 AM
2 point 0's Avatar
Default Re: How to build 200whp ITR Motor (misfit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misfit &raquo;</TD></TR><TR><TD CLASS="quote">you finally changed your signature... but it still sucks.
did you bother to use the search function?</TD></TR></TABLE>
i think he's asking questions because he got smoked by an EG.
Old Aug 28, 2004 | 03:32 AM
b19coupe's Avatar
Cams, cam gears, valve train, pistons, engine management and lots of tuning.
Old Aug 28, 2004 | 04:28 AM
1GreyTeg's Avatar
Default Re: How to build 200whp ITR Motor (b19coupe)
There are people here that have made that magical number with stock cams.
Old Aug 28, 2004 | 06:28 AM
integrasi's Avatar
Default Re: How to build 200whp ITR Motor (2 point 0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 point 0 &raquo;</TD></TR><TR><TD CLASS="quote">
i think he's asking questions because he got smoked by an EG. </TD></TR></TABLE>
yes got smoked & 50 ppl witness it.
Old Aug 28, 2004 | 06:34 AM
esponet's Avatar
my 205whp motor.
jdmitr, head was shaved to the limit, one piece headgasket(yes one piece), toda chiped jdm p30 ecu, vafc, toda spec c, and valve train. toda gears. rpm t/b (70mm) cheap ebay intake. dyned at 205whp 137ft of torque. sadlly i was too dumb/lazy and did not change the timming belt. when it broke it broke the vavle head of the stem and poke a hole on the #1 piston,
Modified by esponet at 8:48 AM 8/28/2004
Old Aug 28, 2004 | 06:49 AM
Rob :190:'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrasi &raquo;</TD></TR><TR><TD CLASS="quote">What do i need to do in order to produce 200whp.
Old Aug 28, 2004 | 07:22 AM
Orange Goats's Avatar
Default Re: How to build 200whp ITR Motor (Rob :190:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob :190: &raquo;</TD></TR><TR><TD CLASS="quote">
haha, that's a good route to go. call me crazy, i think he'd get a little more than 200whp with that
Old Aug 28, 2004 | 07:24 AM
FoShizzle's Avatar
Default Re: (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">my 205whp motor.
jdmitr, head was shaved to the limit, one piece headgasket(yes one piece), toda chiped jdm p30 ecu, vafc, toda spec c, and valve train. toda gears. rpm t/b (70mm) cheap ebay intake. dyned at 205whp 137ft of torque. sadlly i was too dumb/lazy and did not change the timming belt. when it broke it broke the vavle head of the stem and poke a hole on the #2 piston, </TD></TR></TABLE>
how much did you have milled off, and did the timing belt break cause of the age or cause it was so loose, and what do you think the estimated compression was you where running
Old Aug 28, 2004 | 07:41 AM
esponet's Avatar
old age.(i never replaced it from when i got it of the clip) i told the machine shop to mill it 30, but when i got the head, i noticed they milled all the way to the wear tabs, someone told meit was more like 50thousands shaved.
i think my c/r was around 12:1 if not close.(never realle cc it).
if you look at the head you could see the outline of the indicator
after looking at the pic, its #1 that took a chiet.
Old Aug 28, 2004 | 07:51 AM
len's Avatar
len
All you need is CTR Pistons and VTEC Killers and SMSP Header and Hondata Tuning.
Old Aug 28, 2004 | 07:56 AM
Big Phat R's Avatar
Default Re: How to build 200whp ITR Motor (len)
and about $3K for labor/tuning and more tuning
and then more tuning
did I say tuning?
Old Aug 28, 2004 | 08:19 AM
Black R's Avatar
25 Year Member
Modified by esponet at 8:48 AM 8/28/2004</TD></TR></TABLE>
Wow, I'm surprised you had the ***** to mill the head by that much + run a thinner headgasker + toda spec c's..... What was your valve to piston clearance? And what was the maximum advance/ retard of the cams? I'm guessing you didn't have much room to play with there.....
Old Aug 28, 2004 | 08:54 AM
WAFFLES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">old age.(i never replaced it from when i got it of the clip) i told the machine shop to mill it 30, but when i got the head, i noticed they milled all the way to the wear tabs, someone told meit was more like 50thousands shaved.
.030 is to the stops. I just had my head milled .030 and it was flush with the stops.
Old Aug 28, 2004 | 09:12 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: (WAFFLES)
Stock bottom end, cam it up, management or AFC hack, ITBs, there you go.
Old Aug 28, 2004 | 09:16 AM
red civic standard's Avatar
has anyone ever made 200 whp without upgrading the pistons and valvetrain?
Old Aug 28, 2004 | 09:17 AM
Stunna BEN's Avatar
Default Re: (red civic standard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard &raquo;</TD></TR><TR><TD CLASS="quote">has anyone ever made 200 whp without upgrading the pistons and valvetrain?</TD></TR></TABLE>
Yes
Old Aug 28, 2004 | 09:36 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrasi &raquo;</TD></TR><TR><TD CLASS="quote">previously dynoed @ 182whp.</TD></TR></TABLE>
If that's a Dynojet number, that's pretty typical of well thought out bolt on modifications.
If you buy cams you might live to regret it, and in order to get the right power out of them you will have to buy a Hondata or something similar, anyway.
So...I wonder if you don't want to get the Hondata and some cam <u>gears</u> and have it tuned with the OEM cams, first. Odds are that, like me, you will find another ten horsepower and a lot of dirveable torque doing this.
Still on stock cams:
At this point it's clear that adding cams will take me over 200; however, the car's quite enjoyable on the track and in everyday recreational driving just the way it is.
Old Aug 28, 2004 | 09:40 AM
H-T Order of Merit
Default Re: (Be)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Be &raquo;</TD></TR><TR><TD CLASS="quote"><FONT COLOR="red">...ITBs, there you go.</TD></TR></TABLE></FONT>
Not very fond of the ITB idea. Everybody I know who's done it has lived to regret it.
The amount of fuel you use is unbelievable.
Aren't you sitting there w/Jack? Ask him about it. LOL...
Old Aug 28, 2004 | 09:48 AM
mtber's Avatar
Making 200 whp on a USDM itr bottom end is going to be a little hard.
1. JDM itr pistons & a 2 ply headgasket.
This will change your c/r from 10.6:1 to around 11.4:1
2. Aftermarket cams & valvetrain will be a must to easily break 200 whp.
I made 195 on my ls/vtec setup using oem ITR cams,
I can probably make 200 whp if I upgrade my header to something a little nicer.
Check my signature for more details.
Old Aug 28, 2004 | 09:58 AM
Stunna BEN's Avatar
Default Re: (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">[/color]
Aren't you sitting there w/Jack? Ask him about it. LOL... </TD></TR></TABLE>
Nah, was with him yesterday.
Lens car was amazing. Kendall and Tonys hatch was amazing, on a AFC hack.
I might live to regret it as well
But i will part with you here somewhat, because they arent something the normal consumer is gonna have on a H car.
Cosmetic headgasket will help out a good bit, as well as the header you use, in your quest for 200
Old Aug 28, 2004 | 10:35 AM
FoShizzle's Avatar
after looking at the pic, its #1 that took a chiet. </TD></TR></TABLE>
sounds to me with a jdm itr and .030 off the head with a one layer head gasket, you would be running a cr of around 12.8-12.9 kinda high if untuned, i am thinking of milling .020 off my jdm itr and running a 3 layer with skunk 2 stg 2's, how high where you revving yours
