how much power with this B20 setup??
Old Aug 27, 2004 | 11:48 PM
tekstyle's Avatar
Default how much power with this B20 setup??
has anyone done this:
Gsr head with crv b20 block.
gsr crankshaft, and crv pistons.
what's the compression? and how much power gain will this do? i was thinking maybe this can be an alternative to boring out the gsr block. how would this be compared to lsvtec? is it worth going ls vtec if i already have a gsr?
Old Aug 28, 2004 | 10:38 PM
Octoman's Avatar
Default Re: how much power with this B20 setup?? (tekstyle)
Why don't you just build up your GSR motor. Is there anything wrong with it? The money spent doing what you are talking about would be money better spent on your
GSR motor, assuming that it is in good condition. There are many options available to you for the GSR; i/h/e/, pistons, cams, head work and everyone's favorite... Boost.
It is not worth going LSVTEC, you are already there.
Old Aug 29, 2004 | 07:44 AM
matman4444's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekstyle &raquo;</TD></TR><TR><TD CLASS="quote">
what's the compression? </TD></TR></TABLE>
For crv there are two sets of pistons
b20b are the earlier ones at about 8.8:1
and b20z are newer they are closer to 10:1 or somewhere around there
Old Aug 29, 2004 | 08:02 AM
b20vtecv8killer's Avatar
Default Re: how much power with this B20 setup?? (matman4444)
i have a gsr head 1993 and a b20b crv block when the car came out of the shop they told me i had like 195 hp don't know if is true but i can smoke gsr, and si with my set up
Old Aug 29, 2004 | 10:08 AM
matman4444's Avatar
Default Re: how much power with this B20 setup?? (b20vtecv8killer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtecv8killer &raquo;</TD></TR><TR><TD CLASS="quote">i have a gsr head 1993 and a b20b crv block when the car came out of the shop they told me i had like 195 hp don't know if is true but i can smoke gsr, and si with my set up </TD></TR></TABLE>
what tranny are you using? i have the same setup stock but with an si head and i ******* lose to my friends si and he is mostly stock.. but im using a ls so maybe its making me slow
hatchattack02
18
Oct 19, 2011 12:25 PM
x_doug-x
Oct 28, 2010 12:21 AM
philafelman
Jul 2, 2003 04:08 PM
prjctCIVIC
May 26, 2001 12:12 PM
