D16z6?
Old Aug 27, 2004 | 10:43 PM
chron1k's Avatar
Default D16z6?
Will a D16z6 directly bolt into the 90 civic si HB?
Old Aug 27, 2004 | 10:45 PM
yellowcrx1991's Avatar
Default Re: D16z6? (chron1k)
Correct me if I'm wrong, but yes it should, however you'll need to switch to OBD1. Unless you want to be ghetto about it.
Old Aug 27, 2004 | 10:54 PM
Gant's Avatar
i recently had a d16z6 installed in my hatch
everything bolts up except the driver side mount you have to use the mount from ur old engine
in order to activate vtec u have 2 choices
1. convert to obd1 using a jumper harness (thats what i did) it involves using the correct ecu/obd1 dizzy/o2 sensor
2. use ur obd0 and use a vtec controller to activate ur vtec
Old Aug 28, 2004 | 04:12 AM
USDM 4G VTEC's Avatar
check my sig
anyways yes it will.
u gotta use ur stock engine motor mounts in it.. and i even mean the bracket from the driver side that bolts to the engine block
Old Aug 28, 2004 | 06:25 AM
chron1k's Avatar
Default Re: D16z6? (USDM 4G VTEC)
thanx for the replys.
DieMaster
Apr 3, 2006 10:19 PM
KURUPTinc
Aug 14, 2005 10:43 AM
froger
Jul 12, 2005 08:12 PM
kid-crx
11
Apr 17, 2005 02:41 PM
civicdx1
13
Sep 16, 2004 09:33 PM
