thinking about vtec cam upgrade
Old Aug 27, 2004 | 10:40 PM
tekstyle's Avatar
Default thinking about vtec cam upgrade
hey guys. i am thinking about getting some vtec cam upgrade on my gsr. i was wondering if they made a cam that has stock or close to stock nonvtec lobes and a crazy *** vtec lobe? the thing is, i still want my car to pass smog and i know the smog guys arent gonna be dynoing my car at vtec. also, i will get a VAFC if i must with a given cam.
my goals:
- possibly lower my vtec engagement point
- have crazy *** vtec lobes
- have decent non vtec lobes
- upgrading valve train of its springs, and retainers ( will this let me have a higher redline?)
considering the JUN stage 3s or the skunk2 stage 3.
already done a search, but all i found was which cams are best and the specs for them. i didn't find anything on experience or road results.
Modified by tekstyle at 7:50 AM 8/28/2004
Old Aug 27, 2004 | 11:32 PM
shant's Avatar
Default Re: thinking about vtec cam upgrade (tekstyle)
crower
Old Aug 28, 2004 | 12:01 AM
WhiteGSR95's Avatar
Default Re: thinking about vtec cam upgrade (shant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekstyle &raquo;</TD></TR><TR><TD CLASS="quote">hey guys. i am thinking about getting some vtec cam upgrade on my gsr. i was wondering if they made a cam that has stock or close to stock nonvtec lobes and a crazy *** vtec lobe? the thing is, i still want my car to pass smog and i know the smog guys arent gonna be dynoing my car at vtec. also, i will get a VAFC if i must with a given cam.
my goals:
Modified by tekstyle at 7:50 AM 8/28/2004</TD></TR></TABLE>
would also like to know this
Old Aug 28, 2004 | 01:17 AM
anothersickhatch's Avatar
Default Re: thinking about vtec cam upgrade (WhiteGSR95)
it seems like you are asking alot. stage 3's would be too much for what your goals are. stage 3 cams will give you a really rough idle, but you will definatly get a crazy vtec lobe. the primaries on those cams are still pretty sick, which doesnt sound like something you want.
go with a more mild cam, like a stage 1 or maybe a stage2, if you want to stay on the rougher side.
Old Aug 28, 2004 | 02:34 AM
tekstyle's Avatar
Default Re: thinking about vtec cam upgrade (anothersickhatch)
what will i have to set my idle to if i want a decently smooth idle with stage 3?
Old Aug 28, 2004 | 02:37 AM
im not exactly sure..i mean i could give you my best guess but itll be high.
Old Aug 28, 2004 | 02:41 AM
tekstyle's Avatar
hey, a guess is better than no guess
personally, i don't mind my car idling like a harley davidson. as long as it doesnt stall.
Old Aug 28, 2004 | 03:11 AM
b19coupe's Avatar
my goals:
You want the opposite. In other words, the bigger the VTEC lobes, the higher you need to set your VTEC engagement point. For instance: Toda 'D' cams like VTEC set above 7,000 rpm.
Old Aug 28, 2004 | 10:26 AM
tekstyle's Avatar
Default Re: thinking about vtec cam upgrade (b19coupe)
aww damn it thanks man
Old Aug 28, 2004 | 06:29 PM
Highrevs99's Avatar
Jun 3 is what you will want , cars idles fine and makes good top in power and crossover smooth , Toda B will have a little lumpy idle and not as good top end power as Jun 3 and last would be SK2 stage 2 are good top end cams and have stock idle but primary lobes are too small making crossover a bit rough to tune out the dip but they still make good top end power . I just saw you said stage 3 Sk2 , these are too big for a street engine even according to Skunk . You will have to cut the valveguides for retainer clearance and change springs often and need would never pass smog .
Old Aug 29, 2004 | 12:50 AM
riceball777's Avatar
no after market cam will allow you to lower your vtec point only b16 cams will let you do that
Old Aug 29, 2004 | 08:07 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: thinking about vtec cam upgrade (riceball777)
I like my CTR intake cam, VTEC pulls strong.
Old Aug 29, 2004 | 09:52 AM
H22A-AllMotor's Avatar
Default Re: thinking about vtec cam upgrade (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">I like my CTR intake cam, VTEC pulls strong. </TD></TR></TABLE>
Old Aug 29, 2004 | 12:36 PM
tekstyle's Avatar
Default Re: thinking about vtec cam upgrade (H22A-AllMotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A-AllMotor &raquo;</TD></TR><TR><TD CLASS="quote"> I like my CTR intake cam, VTEC pulls strong.
how does it feel at vtec from stock? did you have to reprogram ur ecu or run a piggy back computer?
thinking about the CTR or skunks stage 2s
Old Aug 29, 2004 | 12:42 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekstyle &raquo;</TD></TR><TR><TD CLASS="quote">how does it feel at vtec from stock? did you have to reprogram ur ecu or run a piggy back computer?
thinking about the CTR or skunks stage 2s</TD></TR></TABLE>
Keep in mind I have the CTR intake and B16 Si exhaust cam, The CTR cam pulls a lot harder in VTEC.. If you look at the cam you will notice the larger VTEC lobes. Its just drop in, I added more fuel with VAFC.
Old Aug 29, 2004 | 02:18 PM
tekstyle's Avatar
any different between the CTR exhaust cams and then gsr ones?
Old Aug 29, 2004 | 02:28 PM
Banned
Part # Description Advertised Duration Duration @ .050" Gross Lift w/1.55
Stock Specs from Civic Si Int-265 mid Exh-267 mid Int-219 mid Exh-214 mid Int-.412 mid Exh-.379 mid
Stock Specs from GSR Int-274 mid Exh-276 mid Int-230 mid Exh-216 mid Int-.423 mid Exh-.378 mid
Stock Specs from Civic Type R (JDM Spec) Int-278 mid Exh-280 mid Int-233 mid Exh-224 mid Int-.449 mid Exh-.417 mid
from crower.com
Modified by LSVTEC 91 Civic at 11:44 PM 8/29/2004
hondaeg8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekstyle &raquo;</TD></TR><TR><TD CLASS="quote">any different between the CTR exhaust cams and then gsr ones?</TD></TR></TABLE>
not really...from what i've read.
i'm looking into getting a CTR intake cam for my gsr motor and leaving the exhuast cam alone. i'm going to keep my stock redline though. i'm using a kenji chipped p28 ecu.
Old Aug 29, 2004 | 02:51 PM
yeegsr's Avatar
Keep in mind I have the CTR intake and B16 Si exhaust cam, The CTR cam pulls a lot harder in VTEC.. If you look at the cam you will notice the larger VTEC lobes. Its just drop in, I added more fuel with VAFC.</TD></TR></TABLE>
just curious about "CTR cam pulls a lot harder in VTec," i thought vtec's pulling suppose to be a smooth transittion for most benefit in power bang gain, hard vtec pulling = tunning not precious? (am i wrong or i just have no idea?).
what do you mean by "pull harders?"
Old Aug 29, 2004 | 03:34 PM
tekstyle's Avatar
Default Re: thinking about vtec cam upgrade (yeegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr &raquo;</TD></TR><TR><TD CLASS="quote">
what do you mean by "pull harders?"</TD></TR></TABLE>
i guess its when ur back feels like its glued to the seat more than before. thats how puller harder feels. just a guess. i don't think a smooth transition is anywhere in the equation unless your pirmary lobes are a little more aggressive to compensate for the difference in lift and durations when switching to the vtec lobes.
401tuner
Jun 17, 2007 08:36 PM
O16581724 5 2 5
Nov 6, 2005 09:26 PM
CRXizSLAMM'd
Jul 12, 2004 01:22 PM
christof
Apr 29, 2004 10:20 PM
Hello-Vtec-Goodbye
Apr 11, 2004 04:41 PM
