Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
how loud is 101 db
Old Aug 27, 2004 | 10:19 PM
racekar's Avatar
Default how loud is 101 db
I asked some local track courses like button willow about the sound limit. they said its 101 db limit.
would a side out exhaust be 101 db ? just curious
Old Aug 27, 2004 | 10:56 PM
apexinghonda's Avatar
Default Re: how loud is 101 db (dchung1)
It depends on too many variables most importantly exhaust construction (and where you got it pointed) but that sound limit is a little below the standard db limit for SCCA club racing. Whether you blow the db limit also depends on the temp, humidity and other factors too. One day you may be fine. The next day you are being black flagged. Out comes the steel wool shoved up the exhaust.
Barry H.
Old Aug 28, 2004 | 01:06 AM
PseudoRealityX's Avatar
"pretty loud"
at what distance? at what rpm?
find out where they test it from, and just let off through that section....
Old Aug 28, 2004 | 01:43 AM
rk1951's Avatar
Default Re: (PseudoRealityX)
Its loud, about this loud.
Old Aug 28, 2004 | 01:19 PM
Mike_C's Avatar
pretty f'ing loud...
if a pneumatic drill (95ish) is less than 101 and each point raise is what? 10 times louder than the previous? i'd say 101 is ridiculous.
here is another... as loud as a nyc subway? are they really that loud?
Old Aug 28, 2004 | 01:41 PM
Sean O'Gorman's Avatar
I think 103db is the ALMS limit, and that includes 4 rotor Mazdas and 7.0L V-8s, so 101 is pretty loud.
Old Aug 29, 2004 | 11:40 AM
BrianZ's Avatar
On my integra, I have a strait pipe going back to the stock location. At Sears Point I am 98dB.
Old Aug 29, 2004 | 12:08 PM
Miles85916's Avatar
Default Re: how loud is 101 db (95tegLSS)
i got 104db at PIR portlands international raceway and i swear it doesnt seem as loud but i don't know maybe its because i am in the car. And i am using the Tanabe Racing Medaling full race exhaust
Old Aug 29, 2004 | 06:43 PM
paRRRker's Avatar
i dont want to know how loud my race kar is...its deafening tho
Old Aug 29, 2004 | 07:21 PM
.RJ's Avatar
.RJ
Default Re: how loud is 101 db (paRRRker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paRRRker &raquo;</TD></TR><TR><TD CLASS="quote">its deafening tho </TD></TR></TABLE>
Yes.
Old Aug 29, 2004 | 08:18 PM
ragnaroek's Avatar
cthulward
10 dB has 10 times the intensity, but quantifying 'loudness' from dB is difficult. different frequencies will sound louder than others, hence harley's not sounding too offensive
but hondas are in the nasty frequency range, so 101dB sounds pretty effin loud
Old Aug 29, 2004 | 09:38 PM
sinister6's Avatar
but that 10x db is measured from what rpm range. I assume its from ideal? since stock cars at WOT already closing to 100....
Old Aug 30, 2004 | 03:39 AM
downingracing's Avatar
I ran a straight 2.5" from a 4-2-1 header in my Civic (D16Z6) to the stock location. I got readings of 105db & 106db at Grattan. I installed a turn on the end and the reading went down to 101db/102db (same day). Weather also has a lot to do with sound readings. Rain or damp conditions = louder readings. The muffler I'm installing this winter should get me down under 99db in any conditions.
Matt
(edit for the early morning posting )
Old Aug 30, 2004 | 04:02 AM
Grumpy's Avatar
New User
Default Re: how loud is 101 db (downingracing)
Check this out
http://www.wdcr-scca.org/offic...s.htm
{Powered by VIII}
Mar 9, 2005 01:15 PM
markymarc
Oct 25, 2003 05:13 AM
typeRSXS
Sep 27, 2003 04:15 PM
Tiwe
Sep 23, 2002 08:30 PM
Coaster
Nov 10, 2001 06:46 PM
