Help! Raddling sound when starting in 1st gear from stop...
Hey all,
Just tonight my car started making a pretty loud raddling noise when I am starting to go in 1st gear from a stop. As i let go off the clutch and give it some gas, a loud raddle can be heard from the front of the car (middie/driver side i think). As I accelerate it stops, and then it can be heard just slightly as I shift into 2nd and let go of the clutch.
Any ideas?
Thanks
Any ideas?
Thanks
Your exhaust pipe.. underneath the car, theres a shield that tend to go loose on many hondas. I had the same problem with my car, i just went underneath the car and literally sawed it off because the bolts were all stripped
.. problem solved.. save weight too
OR, i could be wrong and your heat shield
.. problem solved.. save weight tooOR, i could be wrong and your heat shield
Backk InTheDA
Oct 20, 2009 02:52 PM
I've been wondering what that shaking was for a while
