If I need new brake pads at 30,000 miles is that about normal?
Old Dec 4, 2001 | 06:24 PM
Comtechgsr2000s's Avatar
New User
Default If I need new brake pads at 30,000 miles is that about normal?
Old Dec 4, 2001 | 06:50 PM
Willard's Avatar
Default Re: If I need new brake pads at 30,000 miles is that about normal? (Mugenblkgsr2000)
My rears are dead at ~24,000 miles.
The fronts are replaced with Hawk pads for track events.... so I can't say how much longe they will last.
The factory stuff is ~1/2 gone on the front.
Will
Old Dec 4, 2001 | 06:51 PM
B2FiNiTY's Avatar
Sounds normal to me.
Old Dec 4, 2001 | 07:00 PM
New User
Default Re: If I need new brake pads at 30,000 miles is that about normal? (B2FiNiTY)
Thanks everyone!
Old Dec 4, 2001 | 07:01 PM
Warren's Avatar
Wrong-Way Wang
I'd say I need new front pads every 300 miles or thereabouts.
Warren
Old Dec 4, 2001 | 08:01 PM
Edwin's Avatar
Haha.. you're probably not hard on the brakes.
30,000 MILES! That's awesome.
Old Dec 27, 2001 | 11:35 PM
New User
Default Re: If I need new brake pads at 30,000 miles is that about normal? (Edwin)
Hey Edwin, when I ompared my rear brake pads to my new AEM pads the wear was minimal where I could barely see any wear. The front however were so worn I could clearly see how much thinner my pads were.
Old Dec 27, 2001 | 11:41 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
mine went at 11K or so. Will, why did your rears wear quicker than your fronts?
Old Dec 27, 2001 | 11:51 PM
Todatyper's Avatar
Default Re: If I need new brake pads at 30,000 miles is that about normal? (Ross)
He wrote that his rear were almost new and that the front pads were worn out.
Old Dec 27, 2001 | 11:53 PM
Ross's Avatar
25 Year Member
Community Builder
Default Re: If I need new brake pads at 30,000 miles is that about normal? (Willard)
No, I meant Willard:
My rears are dead at ~24,000 miles...The factory stuff is ~1/2 gone on the front.
Will
Old Dec 28, 2001 | 12:12 AM
Peter Lim 1110's Avatar
I went in the dealership to get an alignment at about 45 thousand miles or so.. dont really remember and i asked them to check my brakes for me and they asked me if I just had a new set of pads put in recently because my brakes looked like they had just been changed... I dont know.. something doesnt seem right. 45 thousand miles?? Then again I've had no problems with the brakes ever and they are still running strong(though i do think the lines need to be bled a little). I am still on the original set of pads..
[Modified by Peter Lim 1110, 9:14 AM 12/28/2001]
Old Dec 28, 2001 | 02:36 AM
Brian's Avatar
Thats funny cause I just hit 11K myself and my pads are worn out too. Was hoping they would have more life than that
Old Dec 28, 2001 | 02:37 AM
BudMan's Avatar
Default Re: If I need new brake pads at 30,000 miles is that about normal? (Peter Lim 1110)
You just don't brake hard enough - lol
My HP+ hawks have lasted ~15,000 miles + 3 track days & 1 solo. Not bad for WAY outbraking stock pads & being cheaper to boot. Who cares if they dust a bunch & squeak if you brake easy - it's just an excuse to brake harder!!
BudMan
Old Dec 28, 2001 | 04:32 AM
Willard's Avatar
Track use with Hawk Blues on the front.
The fronts are at ~3/5 of the original thickness. Only street use (and one track session) on those.
Make sure that the rear pads are installed correctly... the piston has a "X" in it. The pad has a little metal kn0b on it... the kn0b has to fit inside the "X".
Will
Old Dec 28, 2001 | 04:38 AM
Mullet_SyTy's Avatar
I've got 34k and the pads look like new all the way around. Is it the track thats killing your pads or what. I'm not exactly a baby on the brakes and they are still thick??? Maybe most you guys are 500 lbs? JK
Old Dec 28, 2001 | 04:44 AM
BudMan's Avatar
Default Re: If I need new brake pads at 30,000 miles is that about normal? (98_ITR#396)
My first track day with this R was with 75% stock pad material remaining. 4 - 30minutes sessions on ~2 mile course (max speed on any straight = 95-100 mph).
When I got home, I noticed some squeaking & found ~ 0-1mm material left on front pads (part of the outside pass side was see-through)!
If you track - stock pads won't hold up at all. After 5-6 laps of 15, everytime they became MUSH! If you are just driving around the street - the stock pads work better then most cars - they just can't handle the sustained high-heat track stopping required for the track.
Dogginator
Jan 24, 2010 01:37 PM
bad-monkey
Honda Motorcycles
12
Aug 14, 2006 06:16 PM
EM2MoNsTeR
Sep 24, 2003 01:25 PM
kod311
Jun 12, 2002 08:09 PM
Comtechgsr2000s
Dec 5, 2001 08:49 PM
