lets talk high compression, and under cam'ing
Old Aug 27, 2004 | 06:46 PM
Dan GSR's Avatar
Default lets talk high compression, and under cam'ing
What would be the consequences of say a 12:1 compression piston with say a stock B16 cam
of course the dynamic compression will be a lot higher than stock
would a higher or lower compression add/lose power, if the cam was not changed
don't give me an argument, that you HAVE to use more aggressive cams, I was just wondering the effects of "under cam'ing "
Old Aug 27, 2004 | 07:15 PM
Used2beAb16's Avatar
Default Re: lets talk high compression, and under cam'ing (Dan GSR)
The only real neg effect could be that if u were running too much static compression, enough wouldnt be leaked out by the small cams, and high compression w.o bleeding off could result in premature engine wear.
integra123
May 10, 2006 01:05 PM
fsp31
11
Jun 7, 2005 05:18 AM
red91g2
Mar 3, 2003 12:12 PM
evo
Jun 12, 2002 03:45 PM
HX_Guy
Aug 22, 2001 02:00 PM
