electric load
From: I told you to wait in the truck in Texas, United States
What's your CRX doing? My CRX idles down after turning on the blower (about 150RPM drop) and especially if I turn on the headlights (a good 250RPM drop). I'm wondering if this is normal on CRX. I noticed the battery is really small, what size should it be?
i was getting same code when i was running a pg7 and a pm6 ecu on my z6 car still ran fine didnt have problems i since switched to a pr3 ecu and the eld code never showed up oh well.
Usually it is your grounds, clean them up, get some fresh metal exposed. The code wont cause your car to not start nor will it affect its performace, my dx threw this code when I did the mpfi swap and I never got around to fixing it, no problems yet.
Which grounds are you talking about? there are lots of grounds but for the engine harness there are the tranny ground and the valve cover ground. There are more but those ones go to the engine.
