help me help my friend (brake noise)
Old Aug 27, 2004 | 04:47 PM
hatchinprogress's Avatar
Default help me help my friend (brake noise)
my friend has a 92-95 civic coupe ex and whenever he lets his foot off the brakes his rear (brakes?) squek? anyone know what that could mean?
Old Aug 27, 2004 | 05:14 PM
eh6's Avatar
eh6
Default Re: help me help my friend (hatchinprogress)
Sensors are going off. Time for brake pads. Sooner or later it's going to squeak all the time.
Old Aug 27, 2004 | 05:25 PM
Default Re: help me help my friend (eh6)
there are sensors for rear brakes??
Old Aug 27, 2004 | 05:30 PM
mingbling's Avatar
brake pads are designed to squeak when they need to be replaced..
Old Aug 27, 2004 | 05:36 PM
IVI's Avatar
IVI
Default Re: help me help my friend (mingbling)
not sensors , squeal indicators.
could be dust in the drums.
Old Aug 27, 2004 | 05:47 PM
hayabusa160's Avatar
Default Re: help me help my friend (IVI)
drums in the back right?
theres these points in the drum brakes that you are suppost to lube if you dont they will sqeak when you let off the brake.
you put that sticky nasty brake caliper lube on those points and it will go away
Old Aug 27, 2004 | 05:59 PM
eh6's Avatar
eh6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">not sensors , squeal indicators.
sensors and indicators...same ****
Old Aug 27, 2004 | 06:50 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
who's car does this not mine
Old Aug 27, 2004 | 06:56 PM
HamandEGgs's Avatar
Default Re: help me help my friend (streetdreams02)
Does your friend's EX have rear drum brakes or rear disc brakes (has ABS)?
If it's only making noise when he takes his foot off the pedal, it could be a loose brake pad caused by something like the caliper not moving properly.
Old Aug 27, 2004 | 07:24 PM
Default Re: help me help my friend (HamandEGgs)
my car used to do it and my friends car did after he replace the brake shoes in the back. so did mines. both of us did not lube those points its like a lump on the back plate of the drum.
like i said theres these points on the drum brake system that the pad will rub on and it will cause a sqeaking.
look in the hemls if you want it tells you to lube these points for a reason.
why would they make sounds after he let off the brake. those sensors or indicators are only suppost to sound when you apply the brakes not let off it.
Old Aug 27, 2004 | 07:50 PM
NineTwoSi's Avatar
Default Re: help me help my friend (hayabusa160)
I think an EX should have rear disc? Correct me if i'm wrong...
Old Aug 27, 2004 | 07:52 PM
Fenrir51's Avatar
It should have rear discs.
Old Aug 28, 2004 | 08:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">my friend has a 92-95 civic coupe ex and whenever he lets his foot off the brakes his rear (brakes?) squek? anyone know what that could mean?</TD></TR></TABLE>
whos car is this
Old Aug 28, 2004 | 08:51 AM
ej1 pilot's Avatar
if the car is equipped with rear disc brakes than its the rear brake pad indicator, the pad on the inside of the rotor has a metal piece sticking out, thats the indicator
Old Aug 28, 2004 | 10:03 AM
Default Re: help me help my friend (Art In Motion)
thanks every one
patrickstar
Oct 29, 2007 04:33 PM
vlc92189
Mar 26, 2007 07:19 PM
R.a.w.
Feb 10, 2006 08:29 PM
RedDC5
Feb 22, 2005 06:30 PM
