Turbo kit, pistons, rods, b16 head etc...
($2000)Vtec B-series Greddy Turbo Kit: TD05H18G. Includes Cast Iron manifold, Downpipe, pipes, Greddy type-s BOV, RC 440 injectors, Walbro 255LPH fuel pump, NOS Fuel Pressure Regulator, Generic Fuel Rail blue box, Fmax 28x6x2.5 IC, Greddy Turbo Timer, B16 tapped oil pan, and all fittings and oil lines. ***turbo is misting a little oil, I recommend that the turbo get rebuilt. 250 at turbochargers.com***
($300) SRP 81mm pistons new in the box with rings
*9.6:1 compression for a B16
*11.1:1 compression for B18C1
($200) B16 Eagle H beam Rods with ARP bolts
($175) 2000 GSR Cams 36K miles
($200) Clutchmaster Stage 3 Clutch 6 puck sprung
* has 150 miles. Still needs to be broken in
($150) P61 ECU 92-93 GSR
*Vtec hits at 5600 RPM
($50) P75 ECU 99 LS ECU
($300) JDM B16A SiR II head
*Comes complete with Cams, Gears, Valves etc…
*No distributor
*Tenzo R red valve cover
($100) OBD-I DOHC Vtec distributor
($50) Polished B16 manifold with throttle body
($50) OBD-I OEM B16 injectors
*No distributor
Pistons on Ebay
http://cgi.ebay.com/ebaymotors...%3AIT
Rods on Ebay
Rods on Ebay
b20ek
Dec 22, 2004 04:08 PM
