Grounding Problem (wacky gauges and no batt charge)
Old Aug 27, 2004 | 03:07 PM
steve_s's Avatar
Default Grounding Problem (wacky gauges and no batt charge)
The gauges on my 93 civic are acting up. When accelerating the tach jumps yet the engine doesnt and the temp gauge jumps all the way up to the red while it isnt overheating. The battery also doesnt hold a charge.
Could this be a ground problem?
Thanks...
Old Aug 27, 2004 | 10:12 PM
steve_s's Avatar
Default Re: Grounding Problem (steve_s)
bump
Old Aug 27, 2004 | 10:23 PM
Ransom's Avatar
Check you dizzy for a loose connection or bare wires for the tach jumping around...As for the battery not holding a charge, Could be a bad cell in the battery or your alternator is ****.
Old Aug 27, 2004 | 10:34 PM
brixity's Avatar
Default Re: Grounding Problem (LudeSH)
i agree check your dizzy... open that up and tighten up all screws that you see. mine did that and it was a screw that had completely come of the coil. don't even know how i was able to drive the car even started bogging bad.
Old Aug 28, 2004 | 12:21 PM
bushfreakz's Avatar
yea same thing happened to me.. was a bad ground and my throttle cable melted as well.. it was the main ground to the battery i think
jrdnvelez
Jan 14, 2011 10:55 AM
big-cat
13
Oct 21, 2009 09:46 AM
PreludePhill
Sep 3, 2006 03:25 PM
t0ekn3e
11
Aug 17, 2006 08:25 PM
SOHCmaster
10
May 29, 2005 10:54 PM
