Radio Fuse keeps on blowing.
Old Aug 27, 2004 | 02:25 PM
Audio28's Avatar
Default Radio Fuse keeps on blowing.
I have a 94 coupe and the radio fuses always blows up. I would put in a new one, start the car then after a few seconds the fuse would blow. I have no idea why it's doing this? Any ideas?? Thanks
Old Aug 27, 2004 | 02:50 PM
TeStUdO's Avatar
Default Re: Radio Fuse keeps on blowing. (Audio28)
you probably have a bad ground or maybe some wires touching. is it an aftermrket radio?? did you install it yourself???
Old Aug 27, 2004 | 03:49 PM
johnny hatchback's Avatar
Default Re: Radio Fuse keeps on blowing. (TeStUdO)
see what else is on the fuse panel using the same fuse. one time i had this problem and it was the wrong sized bulb in my dome light. check little things like that because it might be something simple.
-johnny
Old Aug 27, 2004 | 06:45 PM
Proglow3's Avatar
If you own a multimeter check the amps being fed to the fuse block and also voltage (while the engine is on). This will tell you what your dealing with. I'm thinking that if it's not a bad ground your alternator and it's internal regulator might be going bad.
-Be sure to replace the old fuse with the correct type.
fiveaces
Sep 3, 2008 02:21 PM
show_time
Nov 24, 2007 08:29 PM
monalisa overdrive
Jan 8, 2006 10:11 AM
crx1856
Aug 17, 2003 04:28 PM
green98civic
Apr 18, 2003 12:31 AM
